kent olsen's Avatar
3.0L cam recommendations
I'm looking for some recommendations. This is a street/autox and 2-3 times a year track car in oregon, hint not much use in the winter.
It's a 2200lb 1972T cpe. I will be swapping my 40mm webers, hyd chain tensioners, European headers and M&K 2in 2out "R" muffler from the current 2.7L I have now.
Our host recommends the "S" or modified "S" (whatever that is) and John Dougherty recommends the DC40.
Anyone with any experience with these applications or something else.
Thanks in advance
Kent Olsen
72t upgraded 2.7
Albany, Or
Kent Olsen
72 911 SCT
upgraded 3.0L
McMinnville, Ore
Old 05-24-2008, 08:10 AM
MikeTheYounger's Avatar
+1 on the DC40
I had them in a 3.0 with 46mm PMO's and loved it.
That engine was a little sreamer.
Mike Serrone Jr.
2008 Candy White 2DR GTI DSG :: 1980 SC (Father/Son Track Toy)
///BrooklynAutoRennen | Rudtner's Racing Group | Tyrolsport
Old 05-24-2008, 09:27 AM
Try not, Do or Do not
Henry Schmidt's Avatar
DC40s are a vanilla choice.
I always recommend that sport enthusiasts choose a cam slightly hotter than the spec sheets would suggest. These are small engines in sports cars. Spin the little guys.
Small ports, slightly less compression, lots of cam and lots of ignition timing.
Not once has a customer ever said to me "I wish I put less cam in my motor" but customers quite often tell me the opposite.
Old school, baby.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 05-24-2008, 09:54 AM
Just my .02, but "vanilla" cams are better for AX. Mid range grunt is where it's at...with enough top end to pull 6500 to 7000 without a huge drop off.
Solex brand of vanilla in a 2.7L
A couple pulls on the chassis dyno after 30-40 minutes of break in time. The rings were not totally seated till my first AX....1 & 4 joined the party on about its 10th pass.
Sorry bout the lousy copy.
JPIII
Early Boxster
Old 05-24-2008, 03:43 PM
kent olsen's Avatar
John
What cam would you choose with 40mm webers, 9.5 pistons and headers? Oh and a 915 transmission.
Kent
Kent Olsen
72 911 SCT
upgraded 3.0L
McMinnville, Ore
Old 05-24-2008, 05:02 PM
Navin Johnson
TimT's Avatar
DC-60 or DC-62
might be a good time to buy now...
'69 911 GT-5
'75 914 GT-3
and others
Old 05-24-2008, 05:41 PM
"Back in the day" I both over cammed & over carburated a hot rot engine for what was basically a street car (Chebbie). Lesson learned.
What I would do would be to talk to Steve Weiner and explain your usage.
He gave (& still does whenever I ask) me some good advice. The vanilla motor is the result.
JPIII
Early Boxster
Old 05-24-2008, 07:02 PM
