Wer bremst verliert
JohnJL's Avatar
Perfectbore cylinders: No Gasket?
I am assembling a set of new Perfect Bore 3.2 cylinders with my 3.0 heads that have been machined flat at the perimeter and "dished" a bit and twin-plugged. THe shop that does this is well known for their custom machine work and they had both the cylinders and heads (and pistons) to mock everything up before assembly.
I noticed there are no grooves in the Perfectbore cylinders.
Is it acceptable to assemble them without any head gasket/sealing ring? All the engines I've done before used a sealing ring...
Not much info on the Perfect Bore website...
2007 911 Turbo - Not a toy
1985 911 Cab - Wife's toy
1982 911 3.2 Indiash Rot Track Supercharged track toy
1978 911 3.0 Lichtbau toy "Gretchen"
1971 911 Targa S backroad toy
Old 06-08-2008, 07:18 PM
3 restos WIP = psycho
kenikh's Avatar
Yep, pretty standard stuff. My 2.3 w/ Nickies is the same way. You'll notice Porsche ditched the CE rings on the 964, as well.
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 06-08-2008, 07:44 PM
Wer bremst verliert
JohnJL's Avatar
Thanks Kenik.
Old 06-08-2008, 07:54 PM
