Wer bremst verliert
JohnJL's Avatar
Making A Piston Clip Tool (Guerilla Method)
I was having an aweful time getting the piston clips in on my new JE 98mm coated 8:1 pistons. They have those terrible, heavy spring clips that don't want to bend for anything. I have installed similar ones on my last build but I recall those being less difficult. Maybe the shape of the piston skirt was different on those (95mm 11:1 compression) or maybe JE is just making them even harder
So after trying many of the methods described on other threads I was at my wits' end. So I went searching for materials to make my own tool...
...I went to the hardware store and bought some alu tube with a 20MM OD. I immediately found that the ID was too thin, so that I couldnt' get the circlip to get down inside that tube. It would close as it was inserted so that it couldnt compress any more.
So I went searching the house for anything other tube with an OD of 21MM and an ID as big as possible. I found Barbara's mop handle was exactly what I was looking for...so I stole it...
I then cut the handle off into a 4" section.
I guess I shouldnt be posting incriminating pics...
Then I found that a 14MM socket has an OD just smaller than the ID of the ex-broomhandle.
The experiment continued by using one of my notched screwdrivers (a failed experiment to try what worked for someone else on another thready) to force the clip down into the tube.
Then I held the tube up against the wrist pin...
Then I pushed the socket through the inside of the tube, which in turn forces the clip out and into its groove against the wrist pin. That smile tells the story of that sound when the clip "SNAPS" into place.
Gratituous pic of the perfectbore cylinders and ceramic top/dry film lube sided JE pistons...
I hope that helps someone and doesnt offend anyone who sells tools to do the same...and don't tell Barbara.
2007 911 Turbo - Not a toy
1985 911 Cab - Wife's toy
1982 911 3.2 Indiash Rot Track Supercharged track toy
1978 911 3.0 Lichtbau toy "Gretchen"
1971 911 Targa S backroad toy
Old 06-08-2008, 01:21 AM
911 tweaks's Avatar
necesity (sp) is the motherhod of invention !! Nice job ! Now you need to think of how to dodge the wife when she asks if you have seen her broom... better go buy a replacement one soon...
LOL
Nice job and creative... tell us more about what you are building
Bob
I live for 911 tweaks...
Old 06-08-2008, 03:38 AM
Wer bremst verliert
JohnJL's Avatar
Your 1000th post Bob!
I actually came upstairs with arms up and declared myself the smartest man on earth loudly and repeatedly. The dog looked at me weird.
This is a 3.2 supercharged engine for the race car with a goal of 450 rwhp. 3.0 case and heads, DR20 cams, autorotor supercharger at ~15 psi, air-air intercooler, shortened G50, adaptronic ECU, twin-plugged wasted spark ignition. 3.2 intake with 80MM throttle body. Other goodies too...
Old 06-08-2008, 03:52 AM
notmytarga's Avatar
No new mop needed. Put the rubber handle back on - I see it in the picture - she'll just think see's getting TALLER - I don't know any women who would worry about THAT!
The safety glasses are a good example to all of us.
75 911S Targa - Mine from 2001 until sold to Germany buyer 10/2016
<ALL DIY> Brakes/Wheels '01, Body/paint/restoration 7/04, Suspension 3/07
Engine rebuild - done 7/08 - added 28 tube cooler and SSIs - running strong. Ducktail painted.
2021 MachE, 2012 Outback, 2019 Crosstrek, 2018 Impreza wagon
Old 06-09-2008, 09:07 AM
911 tweaks's Avatar
thx John on the posts... I guess I have been around here for a while... maybe too long ;-)
nice to hear about the build... do you have a post on it so we can follow ?
good pt on the glasses too by notmytarga !!
Best of luck John with the build there !! It looks like she is gonna be a doosie there !!
Bob
Old 06-09-2008, 09:46 AM
Wer bremst verliert
JohnJL's Avatar
I had to pause progress due to shipping delays on head nuts, finally got them this week (took 6 weeks!?!). Installed the remaining clips with the new tool, again it never took more than 2 tries to pop the clips in.
Should have the cam towers on and timing done today, in between naps. I've got the king of all colds, just in time for a sunny 3-day weekend!
While I was waiting for the head nuts I was able to install the new fuel system with a cell and Aeromotive pump in the bottom half of the old gas tank. When its painted up I'll share it, pretty proud of how that came out too.
Old 08-01-2008, 06:38 PM
Enso
Enso's Avatar
thanks for this John
years later lol
glenn
Old 03-29-2014, 01:05 PM
Registered Loser
Why doesn't the Porsche community use the standard circlips like pictured here?
The Porsche original circlips are ridiculous to work with!
Current Rides:: 1987 Red 911 Targa, 2007 R320 CDI, 2003 Red Dodge Ram Hemi, 1993 Beater Jeep Cherokee, Airbus A320
Gone but not forgotten: 1981 VW Scirocco S, 1989 Honda Accord Coupe LXI, F-16C (still my favorite vehicle!),MC-130P, C-130E, T-38, T-37, C150, C172, PA180
Old 03-29-2014, 07:56 PM
Straight shooter
Lapkritis's Avatar
The JE clip issue is specific the 911 application. Their other applications that I've worked with use a smaller diameter wire for the clips and are reasonable to work with. I theorize that perhaps the 911 application is more litigious should a failure occur so they went overkill after being burned by a few owners who blamed the clips. Many sarcastic thanks to those engine builders / owners for ruining it for the rest of us.
“Of the value traps, the most widespread and pernicious is value rigidity. This is an inability to revalue what one sees because of commitment to previous values. In motorcycle maintenance, you MUST rediscover what you do as you go. Rigid values makes this impossible.”
― Robert M. Pirsig, Zen and the Art of Motorcycle Maintenance: An Inquiry Into Values
Old 03-29-2014, 08:54 PM
Wer bremst verliert
JohnJL's Avatar
Remember this from above?
This is what they turned into...
6 engine builds later and I'm still using that broom handle piece and socket to install clips.
Old 03-30-2014, 08:32 AM
JohnJL,
Nice application of guerilla tactics. Now create a tool from the remaining parts of the mop to extract the circlips.
Sherwood
Old 03-30-2014, 01:20 PM
aquazulu2's Avatar
John thanks for the point. I will be needing that soon.
Project list:
Section of metal broom handle
14 mm Socket
Flat tip screwdriver with V groove
I have all on hand I will build tomorrow..
John
Old 03-30-2014, 01:53 PM
