Switch to carbs - O2 sensor
If a switch to carbs is made on a CIS engine, is the O2 sensor still used?
Todd
'81 SC |
The Ox sensor feeds back information to the fuel injection system.
Carbs have no way to adjust to this feedback.
Tom Butler 1973 RSR Clone 1970 911E - Sold but Never Forgotten 914-6 GT Clone |
I guess that was my thinking. So, if I was sourcing SSI's or headers, I wouldn't need to worry about the bunge existing....
Todd
'81 SC |
I would rather be driving
You can plug the O2 sensor bung. The other option (which is a good one IMO) is to buy and install a wide band O2 sensor in its place. use the resulting AFR to make sure your carbs are tuned properly over the entire rpm band. The existing narrowband sensor that your CIS uses will tell you lean or rich but not "how much" lean or rich. They are just not accurate outside a typical 14.7:1 AFR.
Jamie - I can explain it to you. But I can not understand it for you. 71 911T SWT - Sun and Fun Mobile 72 911T project car. "Minne" - A tangy version of tangerine #projectminne classicautowerks.com - EFI conversion parts and suspension setups. IG Classicautowerks |
Wer bremst verliert
As Jamie says, having a provision for an O2 sensor can be helpful later. Not everyone welds Stainless steel either so adding it later can be a pain. But even an intention to tune with an )2 sensor need not be a dealbreaker as you can always clamp a sensor in the tailpipe for temporary tuning.
2007 911 Turbo - Not a toy 1985 911 Cab - Wife's toy 1982 911 3.2 Indiash Rot Track Supercharged track toy 1978 911 3.0 Lichtbau toy "Gretchen" 1971 911 Targa S backroad toy |
