-   -   Chain Tensioners (http://forums.pelicanparts.com/911-engine-rebuilding-forum/417562-chain-tensioners.html)
panzer 07-01-2008 07:42 AM
Chain Tensioners
Can anyone tell me if you can you can apply the Carrera chain tensioner upgrade to a pre 69' chain case?
If yes is there a method of locating the oil line hole?
thanks All!
Panzer
304065 07-01-2008 08:06 AM
You can, but it requires welding a boss on the aluminum cover. If you are going to use non-original tensioners, it doesn't make sense to use the original chain box-- the newer ones have more studs and better sealing and work with the Carrera tensioner covers.
kenikh 07-01-2008 10:12 AM
Or you can do what I did: abandon pressure fed tensioners for 930 tensioner with collars. Depends on if you want it to look original or not.
If you go with pressure fed and dump your covers, I would love to take them off of your hands.
panzer 07-01-2008 12:22 PM
I will go with the pressure fed tensioners; originality is not of importance.
I have the newer style, which I will get prepared for the Carrera upgrade
I kind of blew it sending in the older ones to Ollies thinking it was an easy conversion and found out it might be more difficult when George gave me a look yesterday.
Anyway the pre-69 aluminum chain housings will become available when I pick up all my engine pieces. They have already been cleaned and media tumbled so they look great.
Thank you for the support guys.
Dave
bolt 07-01-2008 06:33 PM
which year 930 tensioners? and/or, does anyone have a part number? I'm preparing to do this in a couple of weeks on my 71T and I want to make sure I use the correct tensioner.
FWIW, I'm going to do the Jerry Woods mod in addition, as many on this board have suggested as a fail safe instead of the collars.
Tom71852 07-02-2008 09:12 PM
Do you have to modify anything else? I've was advised that on the 68 you have to modify the cam.
