What Is It ?
Hello guys,
I get an engine as a core. Serial is 6660338, red fan shroud , CIS , 6 bolt crankshaft... Any idea what is this 2.7 , 3.0 ??? Thanks! |
A third digit of 8, 9, 0 or 1 would be a '78-'81 3.0L. I would imagine that a 6 would indicate a '76 which would be a 2.7L.
The distributor on the 3.0L SC engines turns counterclockwise. Others turn clockwise. You could check that. |
Thanks Brian,
I take a look in the LH crankcase : 930.101.104.0R Thanks! Jim |
If its a 2.7, you'll see a 911/xx. If its a 3.0, it will read 930/xx. The last two digits tell you what it is. |
I recognize that #
it's a 1976 Carrera 3.0, 930/02. They used #s 666 0001 >> the other Carrera engine for that year was the 2.7 911/83 which had #s 666 8001 >> |
Thanks Bill!
So, this engine has a 70.4mm crank but with 6-bolts instead of 9 correct ? Thanks! Jim |
Thanks Steve!
| All times are GMT -8. The time now is 02:51 AM. |
