Less brakes, more gas!
euro911sc's Avatar
Benefits of Slide Valve over other TB designs?
I'm interested in knowing what the benefits/penalties are for slide valve TBs vs. butterfly (or other).
Thanks,
Michael
Michael
'82 Euro SC 'Track Rat' 22/29 Hollows, 22/22 Tarrets, Full ERPB F/R, Rennline Tri Brace, Glass bumpers, Pro 2000's, 5 pts, blah blah blah
'13 Cayenne GTS
Old 06-30-2008, 01:16 PM
3 restos WIP = psycho
kenikh's Avatar
Simple: Slide valves at WOT leave the intake tract completely free of obstruction, unlike a butterfly. Better top end power. Downside (at least on older technology) is upkeep, since they get gummed up pretty quickly. That said, modern flat slide carbs like those by Mikuni seem to have solved this problem., so a similar fuel injection solution could be developed, although I don't know of any today.
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 06-30-2008, 01:45 PM
euro911sc's Avatar
Interesting... I suspect, though, that at any other setting less than wide open, the slide valves create much more of an obstruction to flow... I can't imagine the strange flow at half throttle behind the plate.
Are there any TB's that close on a diameter basis like... er... one of those metal vegetable steamers?
Best regards,
Michael
Michael
'13 Cayenne GTS
Old 06-30-2008, 05:30 PM
euro911sc's Avatar
Best regards,
Michael
Michael
'13 Cayenne GTS
Obstructing flow is the whole point of having a throttle valve. If you didn't want to obstruct the flow you wouldn't want a throttle of any kind.
-Andy
Old 07-01-2008, 12:09 AM
slides
Also remember that slide valves never stick shut ! and the pedal is very heavy at part throttle due to the high vac. pulling down on the slides which makes them not very smooth in part throttle transitions(ie. very heavy return springs) and the maint. is high keeping them clean and free. I also remember that they were not allowed at Indy because of the sticking at WOT issue. But from a flow and power making standpoint hard to beat.
Mike Bruns JBRacing.com
The two most useless things to a driver are the braking distance behind you and nine-tenths of a second ago.
Old 07-01-2008, 05:03 AM
A better solution is barrel valves,.......
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 07-01-2008, 11:42 AM
rs911t's Avatar
Steve, that reply requires a picture
Greg
Old 07-01-2008, 02:43 PM
safe's Avatar
This guy makes custom roller throttle bodies:
http://www.jpmotorsport.se/e/rullspjallhus.htm
Got a price around $6000 when I asked him
Magnus
Old 07-01-2008, 03:09 PM
Navin Johnson
TimT's Avatar
I think Lumenition makes barrel valve tbs. Their website is sucky as usual. Maybe it was Jenvey?
Images from Mad Scientist Racing/Jon Milledge
'69 911 GT-5
'75 914 GT-3
and others
Old 07-01-2008, 06:02 PM
HawgRyder's Avatar
Send a message via ICQ to HawgRyder
If I remember correctly....Kendig used to make a barrel type carb.
It was like an off-set barrel (imagine a disc with the pivot pin off-set to one side) and it "rolled" into the bore.
It was a very smooth action and the venturi effect was always maintained through the complete cycle.
The only place I remember seeing them was at the drag races, so perhaps they also had problems with heavy action.
Bob
Bob Hutson
Old 07-01-2008, 09:10 PM
HawgRyder's Avatar
Just another thought....If you were looking for an older, but very good carb....perhaps an SU might fit the bill.
No accel pump...variable venturi...few moving parts....and great gas mileage.
Bob
Bob Hutson
Old 07-01-2008, 09:14 PM
euro911sc's Avatar
Actually, I was thinking about a valve that closes, but maintains the circular shape of the opening so flow maintains some resemblance of flow... Something that on wide open would look like a pipe and when closed would look like an hour glass.
Steve... ever seen that?
Best regards,
Michael
Michael
'13 Cayenne GTS
Old 07-01-2008, 09:53 PM
Max Sluiter
Flieger's Avatar
Like an iris or the aperture in a camera, right?
I think I know what you are talkin' bout.
Isn't there one at the beginning of Goldfinger?
Old 07-01-2008, 09:54 PM
Max Sluiter
Flieger's Avatar
Old 07-01-2008, 09:59 PM
euro911sc's Avatar
BINGO Flieger! I'm wondering... anything ever done like that?
-michael
Michael
'13 Cayenne GTS
Old 07-02-2008, 08:01 AM
abit off center
cgarr's Avatar
What about a A variable venturi type carburetor? Opens and closes to keep the flow smooth?
______________________
Craig
G2Performance
Old 07-02-2008, 08:08 AM
911 tweaks's Avatar
I smell a cool new design for induction... !
Please share all of your thoughts on how this materializes with the fellow pelicans.
Great ideas here!!
Bob
I live for 911 tweaks...
Old 07-02-2008, 08:09 AM
kenikh's Avatar
I looked into building "iris" type throttle bodies last year. The petal rigidity (or lack thereof) and the technical considerations to make them work in this capacity made cost way beyond what I was willing to wrestle with. Getting an iris mechanism that is rigid and will seal accurately throughout the air flow/vacuum gamut is tough to make work. If you think that the sticking problems inherent with slide valves are bad, you should run your brain along similar lines in regard to irises.
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 07-02-2008, 09:49 AM
911 tweaks's Avatar
good point...
Old 07-02-2008, 09:58 AM
