Oil temperature sending unit adapter
I am installing an oil temperature gauge in my race car. The six cylinder Porsche engine used a 13M X 1.5 thread in the case for the standard VDO sender. The Autometer gauge uses a 1/8 pipe thread for it's sensor. Does anyone make an adapter to go from 13M to 1/8 pipe? Anyone else solved this problem?
Thanks, neilca |
neil, search here for the thread dimensions, I think "accusump" will help
North Hollywoog Speedometer
6111 Lankershim Blvd. North Hollywood CA, 91606 Tel. 818-761-5136 e-mail: info@nhspeedometer.com Pegasus Auto Racing Supplies, Inc. 2475 S 179th Street New Berlin WI 53146 US 1-800-688-6946 US & Canada) |
Thanks guys,
I decided to try and gut the VDO sending unit and tap for the 1/8 pipe. Worked like a champ. neilca |
I have mounted a GM style 1/8 pipe sensor in both the 1/2/3 side chain box cover and the breather housing. Both location yield a temp reading similar to the reading on the factory dash VDO gauge on my 3.4.
Cheers |
| All times are GMT -8. The time now is 02:32 AM. |
