One more time...Broken head studs...
I have a 1977 3.0 engine case (930/02) that I will plan to use.
There is 3 broken head studs : cyl #2 (2 lower) , cyl #1 (1 lower).
The best is to replace all right ?
I do have 964 head studs removed properly (w/o to heat them) can I use them ?
TIA,
Jim
Old 07-17-2008, 10:26 AM
Slumlord
Porsche_monkey's Avatar
Yes, and I think yes.
84 Cab - sold!
89 Cab - not quite done
90C4 - winter beater
Old 07-17-2008, 01:04 PM
Try not, Do or Do not
Henry Schmidt's Avatar
Not a chance. The Delivar studs that came stock in 964 cases are absolute junk. I wouldn't use new ones let alone used heat cycled ones. Delivar studs break. Do yourself a favor and buy something new. I recommend Supertec head studs & you can buy them from our host, but many other choices are available.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 07-17-2008, 02:20 PM
