-   -   Hypothetical engine w/ $30k budget: bottom end (http://forums.pelicanparts.com/911-engine-rebuilding-forum/420759-hypothetical-engine-w-30k-budget-bottom-end.html)
Bill Verburg 07-19-2008 03:32 AM
Lets say that hypothetically you have a $30k budget and want to build a reliable & powerful 3.8 to 4.0 liter air cooled 6
Purpose: mostly DE some street, no emissions or other regulatory concerns
Engine management: Motec w/ itb's, power band in the 5 - 8K range
Lets start w/ the bottom end, case, crank, rods/pistons/cylinders, bearings, oil pump
Where would you start and what pieces (be specific) would you use, what mods if any to the components, rationale is always nice
Steve@Rennsport 07-19-2008 12:17 PM
Bill:
Given the desired operating RPM range and that fact that its going to be a big-bore motor, I would do this:
3.6 case (RSR ones are NLA)
P/C's of choice (bore spigots as needed)
Shuffle pin
GT-3R oil pump
GT-3R crank and crossdrill
Pauter rods
Modify case and center main bearing for the crank mods
JWR rod bearings
Porsche Glyco main bearings (no aftermarket ones)
We make our own ITB/throttle assemblies (46mm or 50mm) and use Motec engine management.
Heads get reworked with our own special RS intake valves (they flow more than OEM RS ones), some port work, and our own P-B guides.
Cams of choice.
1.75" headers for an engine like that and a proper race muffler that incorporates a cross-over or balance tube.
This combo, if properly assembled, works very well,....:) :)
TimT 07-19-2008 01:06 PM
Cross drill the crank, modify the center main bearing. (gets extra oil to 2&5 rod bearings)
GT3 oil pump...Maybe have the bearings DLC coated.
Pauter rods.. Or some Pankl Ti rods if you find some extra change laying around.
Bill Verburg 07-19-2008 02:43 PM
Thanks for the input
Thinking of a 993 case just because it already has the oil filter provisions, obviosly won't use the stock p/c and rods, wont use the heads either. The 993 cam carriers seem to be desireable
Gt3 crank, how is a gt-3R crank different? Fewer after purchase mods?
Gt3 oil pump, how is the Gt-3r different?
Pankle Ti rods, looking for the lightest strongest bottom end possible w/ available parts
There are some very light weight Mahles w/ RSR tops and symmetric pin bores that are going to be available soon, supposedly in the pipe now)
is JWR the NASCAR bearings?
what coating?
Cam/valves/ heads will be another discussion along w/ itbs but as long as you brought it up, Steve how do your itb's compare to TWM intakes
I've recently been exposed to a Motec'd 964 w/ some extremely aggressive cams that work well w/ the stock plenum. A truely amazing car, unfortunately limiteed by stock pistons and rods
Steve@Rennsport 07-19-2008 04:22 PM
GT-3 cranks are stronger and use the earlier, (SC sized) wide rod bearing journals.
GT-3R oil pumps have the biggest pressure side and 3 scavenge pickups. There is nothing better, and there are a lot worse ones. An older 930 pump would be an alternative.
Titanium rods are life-limited parts so budget accordingly. :) :)
Those Mahle pistons are available now but in limited quantities. These run very thin rings and are optimized for racing. Good stuff, for their intended purpose.
JWR bearings are not NASCAR ones: these are custom-made, Calico-coated ones that are FAR better than Glyco's.
Our ITB's are much better than ITB ones with far superior linkage, TB position, and two sizes to choose from. E-mail me directly for some pictures.
Common-plenum intakes simply do not function with cams using narrow lobe centers unless ITB's are used below each runner. We've done a lot of R&D on this and have made some of these systems that mimic the 3.8 RSR intake. That factory system works VERY well but has no provision for any air cleaner. We make a common-plenum system based on a modified 3.6 intake and ITB's, but its too small to make big HP on a healthy 3.8-4.0. :)
TimT 07-19-2008 06:36 PM
JWR = Jerry Woods.. they have bearings that are coated by Calico.
The Nascar bearing require a resizing of the rod throw on the crank... this is getting outside your budget.. Clevite makes some of the bearing we use.. they are actually sort of concave in profile.. and hold alot of oil against the crank, which is a good thing...
DLC is "Diamond Like Coating" Calico does it, as do many other jobbers... Casidium is a keyword...
Racecar Engineering has had some articles in the last few months which highlight Nascar teams use of coatings... DLC etc..
Bill Verburg 07-20-2008 05:30 AM
I understand that, but you mentioned GT3R crank, which threw me
Again I understand the benefit of the Gt3 pump which I believe also has the 3 scavange pick ups, is the GT3r a different pump or the same one?
What is the life expactancy compared to Pauter? Quite a few engines are showing up w/ Ti rods these days
I know about the current crop but there is another more street oriented version coming.
Good to know, is JWR having them custom made for their shop?
Will do
I understand that too, I recently got a ride in a Motec'd 964, stock intake manifold, some truely racy cams, 993 valves, headers, they use MAP and TPS sensors, the thing is remarkably tractable and smooth given the cams. My direction is to itb's anyhow
Bill Verburg 07-20-2008 05:34 AM
The Nascar bearing require a resizing of the rod throw on the crank... this is getting outside your budget.. Clevite makes some of the bearing we use.. they are actually sort of concave in profile.. and hold a lot of oil against the crank, which is a good thing...
yeah, i read Racecar Engineering religiously, wish they included a little more of an amateur oriented slant.
So you think that the JWR coated bearings ins the way to go? Forget the NASCAR bearings that i've seen mentioned?
safe 07-20-2008 12:27 PM
Originally Posted by Steve@Rennsport (Post 4070660)
Bill:
Shuffle pin
GT-3R oil pump
Pauter rods
JWR rod bearings
Cams of choice.
What kind of horsepower are we talking about here, 450-500?
Bill Verburg 07-20-2008 12:36 PM
Ok I looked throught Smartracing and read up on the JWR bearings seems like a good call
Steve@Rennsport 07-20-2008 03:35 PM
One & the same.
Indeed, they are more prevalent and if the motor will see 8K, these do NOT last as long as 4340 steel ones do. Life expectancy is all about how many times the engine reaches or exceeds 8K. IMHO, these things should be regularly replaced as I've seen what happens when they are not. GT-3 Cup engines get new ones every 150 hours and GT-3RSR's every 50 hours.
Yessir, they are.
Magnus,
The ONLY 450-500 HP naturally aspirated Porsche engines I know of are the GT-3RSR ones. The highest HP air-cooled ones make around 415-425 HP and these are all 25 hour engines,...:)
A 3.8 makes anything from 300-425 HP depending on cams, compression, heads, intake system, and exhaust. One's budget & expected engine longevity plays a role in the end result.
blue72s 07-20-2008 07:09 PM
Way too big for 6 cylinders. Read this http://forums.pelicanparts.com/showthread.php?t=384230&highlight=efficient+cylind er+size
TimT 07-20-2008 07:22 PM
Sorry not true..
Our 3.8 GT3RSR engine is pushing over 500 hp
We just built an engine for a customer, 3.7L, we don't have much time on the dyno, but we are already at 400 hp.. give us some more time sitting on the dyno rollers, and I see another 10-15 hp
Bill if this is going to be a mixed use engine, ignore the Ti bling, and the resizing of the crank etc..Drilling the crank and modifying the center main will never hurt.
In Bills Uber hp engine we have Pauter rods with many hours on them... they are bullet proof.
We also have recently built a 3.9 haven't put a fire to it yet though..
Flieger 07-20-2008 08:25 PM
Matteo's car is a 3.9, right?
The Flying Lizards and Farnbacher are using 4.0 Liter Porsche Motorsport development engines in their ALMS 997 GT3RSRs. They had some great speed at Lime Rock and did well at Mid-Ohio. If not for the disputes over racing line and the frustratingly important pit stops, the Porsches could have done a lot better.
Bill Verburg 07-21-2008 05:23 AM
Originally Posted by blue72s (Post 4072547)
I guess I'll have to disagree w/ you.
I've been living w/ a 3.8RS for quite a while now, it just needs a little more flexibilty in the rev department for some very specific conditions. I could also regear(again) but would rather extend the rev range for other reasons.
The reasons more pistons are often better in terms of specific output are manifold, among them smaller lighter components that are easier to accelerate or decelerate and smaller volumes that are easier to fill in a shorter period of time.
Would an 8 cyl flat 6 be a better power plant than a 6 of the same size? Probably, but given that we live in the real world and have to deal w/ what is available....
kojo911 08-30-2008 04:18 PM
Steve/Bill/Tim
Is 400hp achievable w/ $30k in an n/a motor? If so what would be the life expectancy? I'm in motor purgatory too. My car is really well balanced light pretty etc. I'm putting in a g50, would like more hp. It seems the biggest bang for buck is turbo charging. I've seen some pretty sweet dyno charts on single turbo motors, w/ carrera intake plenums, motronic dme' w/ pressure sensing, and twin plug. Torque curves were pretty flat/stable from about 2.5k on (don't hold me to that but I was shocked how much torque was available dwn low and how flat the curves were). Oh and these were running 1bar of boost or slightly less, so I think longevity would be pretty good.
The problem is I like the balance of the car now, and I'm not real psyched about adding a bunch of weight behind the rear wheels. If I thought I could get between 375-400 hp in an n/a motor with out rebuilding it every 50k miles it might be tempting.
ramey 09-01-2008 02:20 PM
ok, requirements are
1) 400 to the wheels *minimum*
2) preferably air cooled
3) no lag; either NA or supercharged (area under the curve is key, so probably an eaton type...i know someone makes a kit but it is bolt on territory only good for 330 or so to the wheels
4) pump gas
5) 75k mile plus reliability on street and track
6) dressed powerplant weight under 500 lbs
what is the budget and what are the probable combinations?
I would guess 3.8 with good aftermarket heads, low compression and custom supercharger tuning with more boost than the off the shelf kits.
I would prefer to get it NA with a 4.2 conversion
I'd love to hear thoughts and real budget numbers.
Steve@Rennsport 09-01-2008 02:50 PM
Ramey,
IMHO, 400 RWHP is simply not possible using pump gas. Further, a 400 RWHP HP N/A engine doesn't remotely come close to a 75K mile lifespan. Measure such things in hours,.... :)
My best advice is to prioritize your list, re-evaluate what is realistic (or not) and define a specific budget because this really decides what will be possible given your resources.
400 RWHP on pump gas usually mean turbocharging and you may not want that.
Porschekid962 09-01-2008 04:08 PM
GT3 RSR case with the oil return holes opened back up, the case itself is slightly thicker.
GT3 RSR or 962 crank with some slight machine work, bearing surfaces DLC coated.
GT3 RSR oil pump.
Pankl (Porsche motorsport) main and rod bearings.
Pankl rod and piston combo, not Ti but designed with a longer rod.
Pankl valves, valve springs and seals.
Jenvey ITB's or adapt an RSR resonance chamber with TB's to an air cooled motor.....
Which Motec?
Coil on plug twin plug setup and staged sequential injectors and two wideband 02 sensors could allow you to run closed loop if the motec is powerful enough. Pectel, McLaren or Bosch are other options that can run on a can bus system to integrate with a logger and dash.
ramey 09-02-2008 08:56 PM
thx steve; that would be getting into serious specific output from under 4.0 NA, but I just needed some input.
I appreciate it. Still working... maybe a SC motor.
BoxsterGT 11-27-2008 04:16 PM
ITB photos
Steve@Rennsport-
I tried to find your ITB throttles on your Website, but could not.
Can you post some photos of them as for this 3.8 motor being discussed?
Thanks.
Len
kojo911 11-28-2008 04:51 AM
Steve/Bill, All,
Fell down the slope, pulled my arms in, and I'm rapidly tumbling. Bought a 993 twin turbo, we're going through the top end, adding garret bb turbos custom intake, injectors and computer tuning. It'll be mated to a G50 trans (thanks for your input bill/steve) w/ custom gearing top speed about 155mph. My hope is to keep the car under 2500lbs, it currently weights 2400lbs so well see. At any rate it should be fun. I'll post pix when I can. Here's one of the car. http://forums.pelicanparts.com/uploa...1227876665.jpg
juicersr 11-28-2008 05:27 AM
Kojo, isn't that the 'gumba' car that was in Excellence a few years ago? I thought that had a N/A 3.6 in it?
kojo911 11-28-2008 08:07 AM
yes it is, I'm the third owner since it was built, still only has 10k miles on the build. Sold the 3.6 to a fellow pelicanite, bought a twin turbo. Long story but the 915 tranny always bothered me, got a shortened g50 w/ custom gearing and guard lsd. Then it went into the "boy, wouldn't this car be great w/ a twin turbo" mode. I'll be happy when its' back togeter. btw the first thing to go was the personalized plates, not my style :)
juicersr 11-28-2008 08:51 AM
Welcome to the 'Slippery Slope Turbo Club'. I always thought that car was really cool, esp with all if it's widebody carbon and kinesis goodness. Also thought i would look really, really cool in black. Come on over to the 930 forum... we would love to follow your fall down the slope...er, i mean build. That's gonna be one fast rocket sled of a mutha at 2400 lbs!
Steve@Rennsport 11-28-2008 10:54 AM
Originally Posted by BoxsterGT (Post 4328265)
Steve@Rennsport-
Thanks.
Len
Len,
Shoot me an e-mail and I'll send you some pictures of our ITB package. :)
vreference 12-01-2008 10:59 AM
As far as the 4.0L is too large for six cylinders argument goes - Does 5.3L sound radical for a V8? That's what the displacement would be if you tacked on another 2 cylinders. 3.8L works out to 5.0L for a V8 version of the same engine. Very average if you ask me.
As far as 400HP out of a N/A 4.0L Porsche engine; no doubt Steve knows a LOT more about building porsche engines than I do but 100+HP/Liter is being obtained on some very reliable daily drivers. Toyotas 2zz is 105HP/L and only revs to a fairly reasonable 7600RPM. BMW managed the same figure with it's 3.2L s54 at 8000RPM although I'll admit that's a fairly high-strung engine not known for it's low maintenance requirements. Throw in the s2000's 120HP/L and rock solid record in the mix for good measure and these are all factory production cars with a warranty backing them up.
The flat six isn't capable of this? Is it the heads? I realize the factory heads are pretty good but they are far from radical - it seems strange there aren't more aftermarket options considering how much money is floating around in the Porsche market.
911nut 12-06-2008 03:00 PM
Juice, that's Rhumba. I ran across the Excellence article today. With a tt it might be able to keep up with your 934 :D
boba 12-06-2008 03:48 PM
It's out there, how about pneumatic valve springs ala F1 in a 911 head. See these guys if $$$$$$ are no object.
www.eliteenginesystems.com
But that was not Bill's original budget.
gtu935 12-16-2008 08:08 AM
All good stuff here. Highlighted by Steve fron Rennsport and Tim T. I agree on all aspects. With the mods and Motec (being the best but very pricy) the budget will strain at 30K. Crank work is imperative, Good rods as well either Pauter or Carillo. NASCAR bearings not so much as your RPM limit doesn't warrant them. ITBs are great, very trick and will yield the most power but, a single throttle set up ie: 964 or 993 type will also yield plenty of power and will be more easily tuned. A high CR will be key in extracting a high power output.
Bill Rudtner
red964 12-16-2008 09:41 AM
id talk to Colin Belton at www.ninemeister.com and come away with a 4.0L+ and 450bhp ish.
<object width="425" height="344"><param name="movie" value="http://www.youtube.com/v/dAkzsrV6BIc&hl=en&fs=1"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/dAkzsrV6BIc&hl=en&fs=1" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed></object>
petevb 12-16-2008 10:10 AM
I talked to him and looked into the 3.8L and 4.0L versions of that motor. Got quotes- neither is cheap. Also realize that at these power levels the motor will need rebuild/ refreshes at least every 25-30 hours. The cost/ performance curve on a n.a. air cooled 911 motor starts to get very steep beyond about 330-360 hp.
red964 12-16-2008 01:17 PM
sure, his 3.8 level with the ninemeister heads, motec, ITB etc would
probably see you towards 370bhp+ and be good for road use.
beepbeep 12-16-2008 02:48 PM
400hp from N/A 2v aircooled engine? I have no N/A expirience at that level but I bet it's going to cost cubic dollars ... cost/performance gets very steep and nonlinear there.
I assume slide throttles, lightweight valvetrain, biggest valves you can fit into the heads, twin plugs, Ti retainers, 906-like cams and Ti rods would be a good start. 4.0L kits have a reputation to be a bit one the edge?
I'll throw in a joker: I would bump compression to 13:1 and run it on E85.
But in the end, If I was to use that kind a budget, I would spend (healthy) portion of that money on lightening the car. Then I would build fairly reliable engine and hopefully still have same HP/kg ratio and lighter car.
petevb 12-16-2008 03:11 PM
I have dynos showing ~425 hp at the motor from the 9M 3.8L; compression was on the high side for road use. This is with the 9M head and cam package as well as their cylinders and pistons. It should be noted here that some feel the 9M dyno is on the optimistic side...
The 4.0L adds a bit more power, largely though a different cam, but it really fills in the torque curve.
I agree you'd better have maxed out weight reduction before you consider spending money on this type of power. The knock-on effect of that much power (stronger transmission, more cooling, ie more weight, which then requires bigger brakes and bigger wheels, etc, etc) is not to be underestimated.
In the end the rebuild schedule is what got me, and they were upfront saying that they would see significant wear when pulling the motors apart at 25-30 hours vs some of the other options. There are other ways to get to those power to weight ratios, even normally aspirated...
Jeff Alton 12-16-2008 04:36 PM
I am one that thinks the dyno is optomistic. Nothing to base it on, but I see lots of dyno claims from english tuners that make me wonder.....
Anyone on this side of the pond used their heads? Done any dyno testing?
Cheers
petevb 12-16-2008 09:16 PM
Cheers
I know Geoffrey Ring of Racetek has a 3.8l version using mahle p&c with the 9m heads, etc. He flowed the heads and generally supports the 9M claims, though one could argue that he works with them enough that there may be a conflict of interest. He has posted dynos on rennlist that show 340 rwhp (roughly 400 crank by his estimate) with 93 octane gas. This is a bit behind a 3.8 RSR sprint motor on the same dyno by his reckoning.
I do believe the 9m heads are very good. Exactly how good is tough to say- it seems the US numbers might be a bit below the UK numbers when comparing claims.
911teo 03-03-2009 11:12 AM
Cheers
I also think their dyno is a little optimistic.
I am having my engine built by them. All 9M components. 3.8L.
I am not that interested in absolute dyno numbers.
Having said that i am planning on comparing my on the same dyno back to back my Ford GT and the 911 with the 9M 3.8L.
The Ford GT makes a conservative 650hp at the crank (couple of mods). We'll see where the 911 will fall.
Extrapolating from their previous build we are expecting between 390 and 410hp from the 911 on their dyno.
petevb 03-03-2009 11:19 AM
Looking forward to seeing how that goes- you're thinking that motor is a few weeks away? I almost went that direction before I was seduced by the dark side. It will be very useful to see numbers from the 9M vs an independent dyno.
-Pete
911teo 03-03-2009 11:34 AM
The engine is in the car and running.
We are waiting for a fuel pressure regulator but I'd say 2 weeks max and we'll have the 9M dyno results...
