-   -   How can you clean fuel rails? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/422430-how-can-you-clean-fuel-rails.html)
JoeMag 07-29-2008 09:49 AM
Have some fuel rails I'm going to be using and I notice rust forming in them. Can these be cleaned up? If so, where?
3.2 CAB 07-29-2008 10:17 AM
Are they the ones used on a 3.2? If so, you can clean them at home just fine. Make sure to plug all of the holes, so you don't get any crap or anything else, inside the fuel rails. I have used a soft, wire wheel, brush either on my bench grinder or on one of my angle or side-grinders. Clean the rusted spots down to clean metal and give the rest a good general cleaning. If you want a "factory new"type of look, there are paint kits that will closely resemble the original yellowish colored, cadmium plating. If not that, you could prime and then use almost any color of paint for engines or transmissions, due to the heat that the fuel rails will be subjected to. It should come out really nice. Good luck!! Tony.
JoeMag 07-29-2008 11:00 AM
...to clarify. The INSIDE of fuel rail has some rust forming.
3.2 CAB 07-29-2008 05:46 PM
Ohhh,... OK. That is a totally different matter. I don't have an answer for you on that.
cgarr 07-29-2008 06:23 PM
You been running a lot of fuel with alcohol in it? May have since thats about all you can get now. Most likely your tank and lines are a but rusty too. You could shake some lead or steel shot in it to clean it up but its going to come right back I would guess. I always run a shot of MM oil with the fuel.
JoeMag 07-30-2008 08:32 AM
Craig -- intestesting thought. ...i have no idea what was run in these. they've been off what ever car they came from for a while. what is MM oil?
cgarr 07-30-2008 08:41 AM
MM=Marvel Mystery Oil
