Flywheel torque question
Yesterday while torquing the flywheel bolts on my 79SC to 88 ft lbs my socket failed. I had used 271 loctite. It failed at 60 ft lbs. Should I remove the bolts and re loctite em, or continue to 88 ft lbs with my new socket?
Old Tee all 911s sold |
Flywheel torque
I think the proper torque for a nine bolt flywheel is 68 ft. lbs........not 88.
Looks like we have a slight mistake in Dempseys book. text on page 139 is ... and for the 1978-89 911s is 120NM (88 ft-lbs) Figure 3-42 shows the process ...
AND Appendix A page 200 says Flywheel bolts (1978-89)..M10X1.25 90NM (66.3 ft lbs. Porsche Technical Specifications (little white book) says 90NM The Bible has a mistake........
of course the later bolts, being smaller in diameter, take a lower torque setting.
You should remove the bolt, throw it in the garbage, and use a new bolt. The flywheel bolts are "torque to yield" type which means they are stretched beyond the yield point. Once stretched to 90NM they cannot be used again. Once stretched to 120NM they REALLY should not be used again. Did you feel the sickening feeling when they stretched, almost like they were going to give way and break? That's them elongating, it's amazing that you can feel it in your hands. For the best explanation ever of TTY I quote the board's own Jim Sims: Quote:
'66 911 #304065 Irischgruen ‘96 993 Carrera 2 Polarsilber '81 R65 Ex-'71 911 PCA C-Stock Club Racer #806 (Sold 5/15/13) Ex-'88 Carrera (Sold 3/29/02) Ex-'91 Carrera 2 Cabriolet (Sold 8/20/04) Ex-'89 944 Turbo S (Sold 8/21/20) |
No, all new bolts. I have plenty of time, will order another set. Thanks,
By the way, how does 271 loctite work? Is there a cure time?
Is there a source that says these bolts are torque to yield. I can see why rod bolts are and they look delicate with the neckdown feature but flywheel bolts don't look like that. I've reused them and am not worried about it. I would however replace the ones you over torqued.
-Andy
72 Carrera RS replica, Spec 911 racer |
Andy,
Try it yourself. Buy a new screw from our host here for $2 and measure the length with a micrometer. Now install it in the flywheel and tighten to the correct torque. You will feel a sickening loose feeling while doing this, almost like you're going to shear the screw in half. This is the screw stretching beyond the yield point. Now take it out and measure it again, you will find that it has permanently stretched. Perhaps we all make too much of these things (I for one plead guilty) but my own view is that if your flywheel comes loose, wouldn't you gladly pay $18 to avoid an engine drop, separation of the gearbox and engine and possible buggery of the crank snout? I certainly would. More info here: Thread locker for G50 flywheel bolts?
'66 911 #304065 Irischgruen ‘96 993 Carrera 2 Polarsilber '81 R65 Ex-'71 911 PCA C-Stock Club Racer #806 (Sold 5/15/13) Ex-'88 Carrera (Sold 3/29/02) Ex-'91 Carrera 2 Cabriolet (Sold 8/20/04) Ex-'89 944 Turbo S (Sold 8/21/20) Last edited by 304065; 08-05-2008 at 06:56 AM.. |
So what is the torque for the 6 bolt flywheel? I just did mine this weekend and used 110 ft lbs. Hopefully that was correct.
Yes, six-bolt is 150NM (110 ft-lb)
I used new on my 2.7 and didn't notice the effect you mention. That being said there have been instances of 6 bolt flywheels coming loose so an abundance of caution is a good idea. For 9 bolt flywheels it would be overkill IMO.
-Andy
