2.7 rebuild
I'm following the steps in Waynes book and am now to the point of checking the piston/valve clearance. #1 and #4 checked out fine. The next step in the book involves installing the rockers for 2,3,5,6. The book doesn't say anything about checking the piston/valve clearance on these. Can I assume that if #1 and #4 are good the rest will be also? This is a stock rebuild with original cams. Deck height measurements were #1 1.51mm, #2 1.32mm, #3 1.4mm, #4 1.31mm, #5 1.37, #6 1.46mm.
Thanks in advance,
Jason
Old 08-07-2008, 08:09 PM
If they were borderline then I'd check them all. If 1 and 4 were not close to the limit then I wouldn't worry about it. Especially for a stock rebuild.
-Andy
Old 08-10-2008, 08:03 PM
