911 fan removal
Just wanted to share my procedure for removing the fan from a 911 alternator without having to resort to using a hammer and punch which can easily damage the fan.
See the attached picture, I use an inexpensive puller with the arms removed and threading nylon ties (they can take up to 75lbs) into the hub of the fan I can easily pull the fan off without distorting it. You can also use a three arm puller to disrtibute the load even more.
Old 08-16-2008, 08:49 AM
Pretty clever...I'll have to try this next time I remove a fan.
Tom Butler
1973 RSR Clone
1970 911E - Sold but Never Forgotten
914-6 GT Clone
Old 08-16-2008, 02:36 PM
Less brakes, more gas!
euro911sc's Avatar
I just run a 1/4-20 tap through two opposite holes (the ones in the center of the fan) and use 2 screws... 1/4 turn each screw repeatably pops it right off in minimal amount of time.
Michael
'82 Euro SC 'Track Rat' 22/29 Hollows, 22/22 Tarrets, Full ERPB F/R, Rennline Tri Brace, Glass bumpers, Pro 2000's, 5 pts, blah blah blah
'13 Cayenne GTS
Old 08-16-2008, 04:53 PM
