-   -   this 2.7 head is for? S RS L ? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/424787-2-7-head-s-rs-l.html)
dan67 08-12-2008 08:36 AM
hallo! this head 2.7 is for?
code 911.104.342.2R
date 10-76
K1819W
intake "over 34"mm
exsaust over 40" mm
thanks!http://forums.pelicanparts.com/uploa...1218555339.jpg
356RS 08-12-2008 10:29 AM
Should be a 76-77 "S" head from CIS engine. Check the intake port size, should be 35mm.
dan67 08-12-2008 11:14 AM
YES! 35mm thanks 356RS
MikeHall 08-15-2008 02:20 PM
Are these heads the same as large port SC heads from 78-79?
Mike
RSstop 08-17-2008 06:16 AM
Mike,
The 3.0 Heads have a larger case stud spacing and will not interchange with the early heads like this 2.7 shown here. The 3.0 also has larger ports & valves.
Lyn
