this 2.7 head is for? S RS L ?
hallo! this head 2.7 is for?
code 911.104.342.2R
date 10-76
K1819W
intake "over 34"mm
exsaust over 40" mm
thanks!
Old 08-12-2008, 08:36 AM
356RS's Avatar
Should be a 76-77 "S" head from CIS engine. Check the intake port size, should be 35mm.
Mark Jung
Bend, OR
MFI Werks.com
Old 08-12-2008, 10:29 AM
YES! 35mm thanks 356RS
Old 08-12-2008, 11:14 AM
Are these heads the same as large port SC heads from 78-79?
Mike
Old 08-15-2008, 02:20 PM
Mike,
The 3.0 Heads have a larger case stud spacing and will not interchange with the early heads like this 2.7 shown here. The 3.0 also has larger ports & valves.
Lyn
Track: 91 C2 SuperCup wannabe, 08 Cayman S
Street: 85 RUF BTR Slant-nose, 70 911 T Coupe Pastel Blue
Projects: 82 911 SC 3.6, 72 911 T Coupe, 74 914 Signal Orange
Old 08-17-2008, 06:16 AM
