Dave Hanning
earlyaircooled's Avatar
can 80mm cylinders be bored to 84mm?
Can 80mm Biral 911E/S cylinders be safely bored to accept 84mm pistons?
1975 Carrera coupe
1974 Targa
1998 Boxster
1999 Boxster
Old 12-23-2011, 11:13 AM
Try not, Do or Do not
Henry Schmidt's Avatar
No, the cast iron is not thick enough.
Even if you could bore it to 84mm the cylinder to head sealing surface would be very thin.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 12-23-2011, 11:43 AM
