Plavan's Avatar
Some pictures of the new 2.5L race motor
Alan Faragallah (Aase Motors) is doing some more magic on my new #2 2.5L. This one will be a little different from my current #1 2.5L (almost 80 hours now and running perfect).
#2 will have a T-crank, Pauter Rods, bigger intake valves. I cant wait to turn this motor over.
Here are some pics of the build.
Chad Plavan
911ST Race Car/2.5L SS Race Motor #02
1972 911T- Numbers matching- Restoring to stock
2011 Porsche Spyder Wht/Blk/Carbon Fiber Buckets/6-Speed (Sold)
2016 Elan NP01 Prototype racecar- Chassis #20, #02
Old 06-06-2007, 07:26 AM
jasam's Avatar
Wow congrats, tell us more about that engine!
There is no substitute
Old 06-06-2007, 09:12 AM
Okay, I get who's Chad, but who's D.J. Asse?
I love you guys outside this forum
-Eric
Old 06-06-2007, 03:18 PM
126coupe's Avatar
Chad,
Are the larger intakes R&D or proven to help?
1967 911R "Clone" Race Car 2.0 & 2.5 Twin Plug
1984 Mercedes 500 SEC
1991 Mercedes 420 SEL
1992 Ford F-350 Dually
28' Pace Trailer
Old 06-06-2007, 04:11 PM
Plavan's Avatar
I think they meant D.J. at Aase... for polishing/ mag the crank....
Minkoff- They have tried it on one other motor... Now it is my turn They were worried about clearance issues with the cam but figured it out. Mine is a little different from the other they built. I think both Randy Aase and Alan came up with the idea. I will dyno when we put it in.
Chad Plavan
Old 06-06-2007, 04:52 PM
126coupe's Avatar
Are you running the new engine at CA Speed?
28' Pace Trailer
Old 06-07-2007, 07:30 AM
Plavan's Avatar
No. Shooting for Sept. in Buttonwillow.
Chad Plavan
Old 06-07-2007, 07:33 AM
Plavan's Avatar
Almost done! Zoooom, Zooom
Chad Plavan
Old 06-17-2008, 08:02 AM
Nice!!!
Looks like the all of the cylinder air deflectors and right-side oil return tubes haven't been installed yet.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 06-17-2008, 09:32 AM
Plavan's Avatar
I decided not to run oil cuz it is too expensive
Yep- Just piston/valve cam clearance test... it passed
Chad Plavan
Old 06-17-2008, 09:35 AM
Peanut oil is the answer,.....doesn't smoke til almost 500 degrees and it smells great,.......
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
Old 06-17-2008, 09:47 AM
Plavan's Avatar
These just in. Just needs shroud, oil cooler, late T-stat, and some oil lines.... all done
Yum yum.
Chad Plavan
Old 08-19-2008, 08:48 AM
Jeff Erickson and Allan Faragallah-Aase Motors have been producing high horsepower but reliable engines for racecars for years it is nice to see their customers brag on them a bit.
Both are very Humble and probably let the record of SCCA and Porsche club as well as IMSA victories do the talking, I think its great when someone calls a little attention for the lads in West Fullerton.
regards
Old 08-19-2008, 10:00 AM
304065's Avatar
Chad,
Awesome, beautiful work.
Those are some big barrels!
What is the story with the later thermostat?
Also it looks like a later intermediate shaft cover plate, I assume the case was machined for the later shaft!
Can't wait to see (and hear) the numbers.
Nice!
'66 911 #304065 Irischgruen
‘96 993 Carrera 2 Polarsilber
'81 R65
Ex-'88 Carrera (Sold 3/29/02)
Plavan's Avatar
John- We had the case machined so you can use the later T-stat. The later ones are alot cheaper and easier to find, probably more reliable too.
Yes- it has the later intermediate shaft and machining work- nice eyes. Not that anything is wrong with the early shaft.
Did you notice the shuffle pinning?..... That was kinda a mistake on this aluminum case, but I guess it will not hurt
I can't wait till it spins to 8k RPM . With Pauter rods and a 911 T crank..... it will scream.
Aase guys are meticulous!
My current 2.5L will be rebuilt- with twin plug this time
Chad Plavan
Old 08-19-2008, 06:40 PM
sww914's Avatar
It's really nice to see the names of the responsible parties on the various pieces, total accountability. A former co-worker once worked at a place that built special engines. He etched his signature on the top of the case of every engine that he built. They asked him to stop doing that and he refused. It was a big deal. He stood his ground and kept signing every engine and they gave in eventually. They could see the pride involved.
Old 08-19-2008, 07:36 PM
911 tweaks's Avatar
Chad,
I totally agree with all of the other congrats... a top notch shop and job here.
A quick question, do I see you will be using the cam oil line restrictors to bump up oil pressure ??
Also, can you clue us in on the cam specs & valve sizes and I presume a 66mm crank ?? Any idea on the hp at what rpm ??
Thank you in advance and appreciate your sharing this engine magic with us.
Bob
I live for 911 tweaks...
Old 08-20-2008, 05:29 AM
Plavan's Avatar
Originally Posted by 911 tweaks View Post
Chad,
Bob
Thanks Bob. I can take those engines apart no problem, I just do not trust myself putting them back together You can see their attention to detail all over that motor. If I built it (and it actually ran) it would never be that clean.
Yes, it will have the oil restrictors.
The specs are the same as my current 2.5L motor except for the "T" 66mm crank, DC60 cams, and 993 intake valves
I'm guessing it will have a little more low end torque than the GE80 cams on my #1 motor. We had to use the DC60 cams for proper valve clearance.
This motor should put out more HP than my current motor.
Here is the dyno sheet from my current 2.5L motor (#1).
I will dyno #2 once I get it in the car and break it in.
Chad Plavan
Old 08-20-2008, 07:07 AM
