whackit's Avatar
Too short new Mahle 2.7 RS Cylinders, Anyone heard about these?
Hi all,
I have a new set of pistons and cylinders from Mahle, a 2.7RS euro set. My deck height required much more shimming than either me or my machinist (he is the best... guess who) thought was normal. It turns out that Mahle made a bunch of 2.7RS sets that had too short cylinders. Has anyone else heard about this? I'm just not too keen on running my new engine with a pile of shims under it.
Thanks.
1971 911E 2.7RS interpretation -- Signal Orange baby!
Old 09-30-2008, 07:09 PM
Warren Hall Student
Bobboloo's Avatar
What's the height group marking? I can't imagine how Mahle could sell a cylinder that doesn't match it's height group marking.
How much deck height do you need to make up?
Lot of good machinists. My favorites in L.A. area are Walt and Ollies.
Bobby
_____In memoriam_____
Warren Hall 1950 - 2008
_____"Early_S_Man"_____
Old 10-01-2008, 09:11 AM
We haven't seen any issues with current 90mm RS P/C's, but that doesn't mean there isn't a problem out there.
I will mention that when the case gets decked (as it should) and if the case halves are machined and centerlines bored back to standard, the whole assembly gets slightly narrower and so sometimes thicker base gaskets are needed to hit the desired deck height figures.
Like Henry, I don't ever use more than two of these on each cylinder and I have sources for a range of sizes to set everything up properly.
Sounds like more investigation may be needed,.....
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 10-01-2008, 09:48 AM
whackit's Avatar
I have to make up 1.75mm which will require 3 shims which I am trying to avoid. It seems the short cyls was a rumor, I can't find a source for .75mm shims. I may tru to get away with 1.5mm which will put me right at 1mm but I had my heads cut so that worries me.
Old 10-01-2008, 10:30 AM
Warren Hall Student
Bobboloo's Avatar
Cutting the heads won't affect your deck height but it will affect valve clearance and CR.
Bobby
Old 10-01-2008, 10:51 AM
abit off center
cgarr's Avatar
Were the case halves shaved for boring?
______________________
Craig
G2Performance
Old 10-01-2008, 10:59 AM
whackit's Avatar
yes, shaved, bored, decked. done by walt.
it's the valve clearance that worries me. I'll be running E cams. Not so worried about CR as it's the 8.5:1 set
Old 10-01-2008, 11:12 AM
304065's Avatar
What is the measured cylinder height?
'66 911 #304065 Irischgruen
‘96 993 Carrera 2 Polarsilber
'81 R65
Ex-'88 Carrera (Sold 3/29/02)
Old 10-01-2008, 01:02 PM
whackit's Avatar
it's correct. I measured it against an old cylinder I had. 85.5mm
Old 10-01-2008, 01:26 PM
abit off center
cgarr's Avatar
Shaving the case is going to change your deck, how much did they take off the case?
Craig
G2Performance
Old 10-01-2008, 02:03 PM
There you go,....
Thats why you are having the difficulties.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
Old 10-01-2008, 02:28 PM
