Too short new Mahle 2.7 RS Cylinders, Anyone heard about these?
Hi all,
I have a new set of pistons and cylinders from Mahle, a 2.7RS euro set. My deck height required much more shimming than either me or my machinist (he is the best... guess who) thought was normal. It turns out that Mahle made a bunch of 2.7RS sets that had too short cylinders. Has anyone else heard about this? I'm just not too keen on running my new engine with a pile of shims under it. Thanks.
1971 911E 2.7RS interpretation -- Signal Orange baby! |
Warren Hall Student
What's the height group marking? I can't imagine how Mahle could sell a cylinder that doesn't match it's height group marking.
How much deck height do you need to make up? Lot of good machinists. My favorites in L.A. area are Walt and Ollies.
Bobby _____In memoriam_____ Warren Hall 1950 - 2008 _____"Early_S_Man"_____ |
We haven't seen any issues with current 90mm RS P/C's, but that doesn't mean there isn't a problem out there.
![]() I will mention that when the case gets decked (as it should) and if the case halves are machined and centerlines bored back to standard, the whole assembly gets slightly narrower and so sometimes thicker base gaskets are needed to hit the desired deck height figures. Like Henry, I don't ever use more than two of these on each cylinder and I have sources for a range of sizes to set everything up properly. Sounds like more investigation may be needed,.....
Steve Weiner Rennsport Systems Portland Oregon (503) 244-0990 porsche@rennsportsystems.com www.rennsportsystems.com |
I have to make up 1.75mm which will require 3 shims which I am trying to avoid. It seems the short cyls was a rumor, I can't find a source for .75mm shims. I may tru to get away with 1.5mm which will put me right at 1mm but I had my heads cut so that worries me.
Warren Hall Student
Cutting the heads won't affect your deck height but it will affect valve clearance and CR.
abit off center
Were the case halves shaved for boring?
______________________ Craig G2Performance Twinplug, head work, case savers, rockers arms, etc. |
yes, shaved, bored, decked. done by walt.
What is the measured cylinder height?
'66 911 #304065 Irischgruen ‘96 993 Carrera 2 Polarsilber '81 R65 Ex-'71 911 PCA C-Stock Club Racer #806 (Sold 5/15/13) Ex-'88 Carrera (Sold 3/29/02) Ex-'91 Carrera 2 Cabriolet (Sold 8/20/04) Ex-'89 944 Turbo S (Sold 8/21/20) |
it's correct. I measured it against an old cylinder I had. 85.5mm
abit off center
Shaving the case is going to change your deck, how much did they take off the case?
There you go,....
![]() Thats why you are having the difficulties.
