About to show my ignorance, many questions
my car currently has a very strong 2.7 liter air cooled rs motor(magnesium case if that matters). Has TWM fuel injection and stand alone computer. Puts out 240 hp and 200 lbs of torque. Case is shuffle pinned and sturdy as can be
Now I have read many times about twin plugged RSR motors and needless to say I have visions of converting it to a RSR motor.
What I would love to have is a motor that puts out 350hp. If at all possible 400hp.
Keeping the car naturally aspriated what would I have to do?
Can a 2.7 be made into a 3.0 or 3.2 etc? 3.5 even?
With good spark plugs(like iridium?) what kind of compression can I get? 11-1 possible?
I would like to go with a megasquirt ecu since the haltek in there is very outdated. I was also looking at the AEM pencil coils. Figure that would give better performance then the current ecu. But more importantly I would like to be able to learn more about the engine management myself.
I figure the ecu and electronics are gonna run around 2k. What about the engine work? I really don't know for sure but figured 4k for that so don't laugh to hard
Nathan
Old 08-26-2008, 04:11 PM
dtw dtw is offline
GAFB
The simple answer: You cannot open up a 2.7 bore spacing to a large-enough motor to make 350+ hp 'down low', nor can you spin a 6-bolt flywheel fast enough to make 350 hp 'up high'. Start with a 3.0 or 3.2 case and give Henry Schmidt or Steve Weiner a call, and you'll be set...
Several BMWs
Old 08-26-2008, 07:34 PM
3 restos WIP = psycho
kenikh's Avatar
Originally Posted by dtw View Post
...nor can you spin a 6-bolt flywheel fast enough to make 350 hp 'up high'.
Actually, you could, but it would be expensive. An early turbo case with oversized Nickies could get you there, no guarantees. BIG dollars, too. Easiest way would be to buy one of Henry's 9 bolt 66mm cranks, drop it in a 3.6 and design it to rev big. A well designed short stroke 3.3 would easily hit 350HP. It won't happen for $4K, but could be done for $14K if you did a lot of the work yourself.
These cars ain't cheap. A turbo would certainly be cheaper; those power numbers are easily reachable and power comes on LOW.
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 08-26-2008, 08:54 PM
Thats a bit disappointing. But good to know. I assume making it into a 2.8 rsr is still possible.
Old 08-26-2008, 09:51 PM
kenikh's Avatar
Possible, but still over $4K and not advisable.
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 08-26-2008, 09:59 PM
really why wouldn't you advise doing that?
Old 08-26-2008, 10:06 PM
kenikh's Avatar
It is simply a matter of cost. It would be much cheaper (and more reliable) to build a later 3 liter into RSR specs. The myriad of complications in building a 2.8RSR motor is covered in numerous threads on this site. Let's just say that getting P/Cs to work with 2.7 heads is punitively costly; either you buy Nickies and JEs ($3K in parts) or used Mahle 2.8RSR (if you are lucky) and spend $2K on top of what you spent on the P/Cs to get the heads opened up so you aren't running 12:1 CR. Either way, you are going to be into a 2.8RSR for about $4K in parts, before the labor starts, from a 2.7.
A 3 liter, you just buy a nice runner, swap the pistons out for JE ($900), get some hot cams ($700) and you can do the labor yourself (free). And case is aluminum (no need for shuffle pinning).
I am just scratching the surface here, too.
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 08-27-2008, 03:02 PM
3.2 CAB's Avatar
Damn Kenik, you even got me convinced of that being way to go, and I am not going to be doing any engine work. I like my 3.2 just fine as it is. Good luck!! Tony.
84' Steelslantnose Cab.
1953 Dodge B-4-B-108" 90,127 miles
1953 Dodge B-4-C-116" 58,146 miles
1954 Dodge C-1-B8-108" 241V8 POLY
1973 Roadrunner 440-SIX-PACK*
1986 F-250 Super Cab-460 V8 tow
Newest additions-
Matching numbers 1973 340 Road Runner!!
1948 Dodge B-1-F-152" 1-1/2 ton Dump body, 39,690 miles
others...
Old 08-27-2008, 10:38 PM
You are going to see so little gain going to a 2.8 over a 2.7 that you might as well stay with the 2.7, up the compression and twin plug it
Robert
Currently Porsche less (but the wife has 2)
Old 08-31-2008, 07:23 PM
Sell the 2.7 and buy a 3 litre to make your race engine out of.
-Andy
Old 08-31-2008, 09:51 PM
Author of "101 Projects"
Wayne 962's Avatar
With a 3.2 base, you can make a 3.4 engine, and then maybe if you pump up the compression and run race gas all the time, you might be able to get to that 100 hp / liter number on normal aspiration. 400 HP is near impossible, in my opinion.
-Wayne
Old 08-31-2008, 10:26 PM
I just remember reading about the 2.8 liter rsr making 315hp. With modern engine management and new technologies I figured they could put out even more. Where those numbers fudged?
Thanks for you input guys!
Old 09-02-2008, 02:03 PM
