-   -   E cam numbers (http://forums.pelicanparts.com/911-engine-rebuilding-forum/427699-e-cam-numbers.html)
speedo 08-29-2008 05:09 PM
E cam numbers
Are the the correct part numbers for an E cam set?
901 105 110 0R
901 105 181 0R
Thanks!
Speedo
jbell959 08-29-2008 08:47 PM
Those are the correct casting numbers for MFI E cams but if you want to be safe I would send them out and have the profiles checked. The 110 casting number was also used on early Solex engines with a different grind.
