E cam numbers
Are the the correct part numbers for an E cam set?
901 105 110 0R
901 105 181 0R
Thanks!
Speedo
Old 08-29-2008, 05:09 PM
Those are the correct casting numbers for MFI E cams but if you want to be safe I would send them out and have the profiles checked. The 110 casting number was also used on early Solex engines with a different grind.
1970 911E Sportomatic Albert Blue
1971 911T Sunroof Coupe w/ Twin Plug 2.5 MFI
1973 911E Glacier Blue
1973 911E RSR Tribute Viper Green w/ 3.5 Twin Plug MFI
Old 08-29-2008, 08:47 PM
