Another way on a Bridgeport knee mill after traming the head is a automatic boring head. But I think you will appreciate Henry that its way faster in a cnc than in a lathe or manual mill especially when you find a head that needs a .001" more to clean up and you have the other 5 to redo. |
What we do to avoid the necessity of re-machining the heads is to accurately measure all the heads, make an informed decision based on experience as to the head with the greatest deficits and machine that head first. This method allows for a clean mating surface with the least amount of material removed. http://forums.pelicanparts.com/uploa...1617805295.jpg |
Studs are removed yes and whilst they are out, they are plated, cam tower dowels no, that would be dumb. I think it would be foolish to buy a cnc to re face 911 heads, But when you have one due to your other engine work developing race engines for Single Seaters and making hundereds of parts. I have refaced heads using all 3 methods and adside from removing the the studs its the superior method if you happen to have a CNC http://forums.pelicanparts.com/uploa...1617825952.jpg
http://forums.pelicanparts.com/uploa...1617825975.jpg |
Milling machines are higher precision than lathes too.....
The tolerance for machining heads is +or - .02mm or .00078".
If your lathe can't hold 8 tenths you might as well have a beaver chew on it. http://forums.pelicanparts.com/uploa...1617839504.jpg |
It was a factual statement, Henry, not an opinion......
Both machines are capable of accuracy far better than needed on machining engine parts.
My good machinist friend who works in aerospace has a CNC lathe that can make parts to 2 micron tolerance. Is that precision needed for engine parts? Nope. |
Oh my God....all I said was that milling machines are higher precision than lathes. That's a simple fact. You know, like 2 + 2 = 4.
Oh my.....
Reading some of these posts is like listening to my 14 year old grand daughter. Absolutes vehemently proclaim as factual. It's as simple as 2 diamonds plus 2 radishes equal 4 diarads. |
https://www.usimn.com/cnc-lathe-and-mill-difference/
I was not arguing suitability.....if you have a CNC milling machine and don't have a lathe, like drgouk, a milling machine is a reasonable choice. |
Relax. I just wished that some day I could be as good as this guy with a hacksaw.
https://www.youtube.com/watch?v=-KPWEG_O9M4 |
I don't think any method offers better accuracy, as you should have the suitable equipment to do the job in the first place, in good serviceable condition. The accuracy of this procedure will largely be down to the clown driving it. My remark about doing the heads on the CNC, being superior, relates to the speed at which the heads can be re faced, and re done if required to clean the sealing face. The accuracy also comes down to the clown driving it, as firstly you must clock up a jig and probe the head to get Z zero. Get those things wrong and it be worse than the other 2 methods. Henry, do you measure your heads prior to machining with a clock on the sealing face, heads on parallels on cam tower tower sealing face? To determine the lowest head? or another method? |
Definition: There are multiple ways to accomplish a goal. Quote:
One clear benefit to using a mill is the ability to modify the chamber cto produce a custom chamber or repair anomaly (IE: damage from an explosion). Now a question for you: how many 911 Porsche head have you machined and what do you charge? |
For QC, I use the above method to check my work and establish if a barrel shim is required. I haven't been keeping a tally on how many heads I've machined to date. As far as price, I charge by the hour and I normally only do internal work. Its not the main focus of my business, Its a sideline. As I mentioned, I build a lot of single seater race car engines, Hence why I have a CNC making race engine parts or I would be beavering away on a lathe :] |
The answer is: you haven't done many Porsche heads and you don't have Porsche customers or quoting a price would be simple. |
I bet I have more New Porsche inventory in my shop currently for customers, How many new Porsche cases do you currently have in your shop?
bragging rights
What tool do you measure this with for this moment.PEKKER on the table.What is the size for this argument?Ciao
| All times are GMT -8. The time now is 07:38 PM. |
