Megasquirt ignition map table sample
Anyone out there have a megasquirt 3 (or 2 for that matter) ignition map i could use as a sample baseline to start from.
Old 02-25-2012, 10:33 AM
mppickett's Avatar
This is what I run on my twin-plugged turbo with a full-bay intercooler.
07 Audi A4 2.0T Cabriolet - Black/Black (sold)
96 993 C2 Cabriolet - Arena Red/Tan (sold)
82 911SC - 993 Turbo Cab Trib - Speed Yellow/Black (sold)
58 DKW Universal - Baby Crap Yellow/Beige (sold)
Old 02-25-2012, 03:56 PM
Thanks. Iprobably can work from this, but if someone out there has a nonturbo map that would be better
Old 02-25-2012, 03:59 PM
would be better
Old 02-25-2012, 05:03 PM
This thread has a few ignition maps. There are other threads out there on Pelican as well. The megasquirt forums have many maps that people have uploaded as examples as well.
W
tuning programmable engine management systems
Good discussions all the way through the thread
-Wade
1972 Targa, nothing matching.
Looking for motor 6124265 and transmission 7720299
Old 02-26-2012, 07:31 AM
Turbonut
Raceboy's Avatar
I have hard time understanding why you need 25 degrees of advance in lower areas and 15 degrees in idle areas? 964 and 993 run ~0 degrees of advance in idle, single plug would be good around 8-10 degrees, depending on the cam choice.
More advance means worse fuel economy as engine needs to work harder against combustion during low loads.
'83 924 (2.6 16v Turbo, 530hp),'67 911 hot-rod /2.4S, '78 924 Carrera GT project (2.0 turbo 340 hp), '84 928 S 4.7 Euro (VEMS PnP, 332 HP), '90 944 S2 Cabriolet
http://www.facebook.com/vemsporsche
Old 02-26-2012, 10:55 AM
Swade. I could not find on the ms forums any maps for 911s. The thread you pointed to looks to contain the motronic maps, which while i have them, if i can find ms ones i wont have to extrapolate the data
Old 02-26-2012, 12:53 PM
mppickett's Avatar
Note that the 25 degrees are in areas of the map that are only encountered if the engine is dropping off of full throttle or has slowed down too much (MAP readings of 20 or below or RPM less than 400 in non-start mode). The extra timing helps to prevent a stall when coming off of throttle. It is a rarely encountered state. Why 15 degrees at idle? This engine feels perkier at that setting. Yours might feel different unless you've got similar compression, intercooling, cams, etc. This is one of those situations where it works fine in practice but will never, ever work in theory.
Old 02-26-2012, 05:11 PM
Turbonut
Raceboy's Avatar
I tuned 964 engine with 5gas analyzer and the engine idled smoother and burn was cleaner (less NOx) with lower advance, also fuel consumption on idle was down. No issues with throttle response either, engine is very crisp.
Do you have ignition based idle control? That would neglect the need for such steps in ign table as it would hold the rpm steady by adjusting advance automatically (compensates for power steering, aircon etc).
Old 02-27-2012, 12:51 AM
