What distributor to use?
1968L 2.0L Block, RS spec heads, High comp. Pistons, Race Gas, Haven't decided on the cams yet. Track only car.
1970 914-6 GT Track Car
1974 IROC Track Car
1987 911 Targa 3.2
2008 BMW X5
Old 10-28-2008, 07:02 AM
Distributor
If you are needing twin plug take a look at our 12 pin distributor for the 2.0 - 3.8 911, the web site is JBRacing.com, do a search for Minkoff he has some nice pics on pelican of one in his race car and a few things to say about it. We build them in house and they work very well.
Mike Bruns
The two most useless things to a driver are the braking distance behind you and nine-tenths of a second ago.
Old 10-28-2008, 07:10 AM
David,
To elaborate a little, high compression on a 2.0 means deep valve clearance pockets in the piston, and deep dome 2.0 heads make a terrible combustion chamber for flame travel.
You really a need twin plug distributor like Mike sells for a high compression 2.0
Lyn
Track: 91 C2 SuperCup wannabe, 08 Cayman S
Street: 85 RUF BTR Slant-nose, 70 911 T Coupe Pastel Blue
Projects: 82 911 SC 3.6, 72 911 T Coupe, 74 914 Signal Orange
Old 11-01-2008, 07:36 AM
