which Oil Pump for 7R mag case (project 66x92Mfi)
which Oil Pump for 7R mag case (project 66x92Mfi)? carrera 84/89 or 77-83 1/2?
thanks
Old 09-02-2008, 12:03 AM
3 restos WIP = psycho
kenikh's Avatar
thanks
They are basically the same, except for the screen on the intake side. The question you should ask is:
SC/Carrera
Turbo
GT3
I'd probably go with the SC/Carrera unless you are going to race it.
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 09-02-2008, 11:55 AM
the 996 turbo pump its suitable?
Old 09-09-2008, 02:35 AM
or 964?
Old 09-12-2008, 09:48 AM
kenikh's Avatar
996 and 964 are great pumps.
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 09-12-2008, 09:52 AM
Fast Corners's Avatar
+1 on the 964 Pump. I have one in my '73. You need to machine the case to accept the longer pump and you need to order the shorter aux shaft coupler. Since I purchased my pump and installed it I have been told that the 996 pump is even better...then again how much better does it need to be with a 7R case?
FC
'73 911 Track Car
'99 996 Daily Driver
'93 968 Wife's Car
'05 Cayanne S Family Car
Old 09-12-2008, 10:00 AM
up-fixing der car(ma)
YTNUKLR's Avatar
Send a message via AIM to YTNUKLR
The 964 is magnesium, prone to crack, I wouldn't recommend it
996 is Al, it's a good unit
Scott Kinder
kindersport @ gmail.com
Old 09-12-2008, 04:35 PM
Wer bremst verliert
JohnJL's Avatar
If you decide on an SC pump, I have a known-good one for sale cheap. I replaced it with a GT3 pump as the engine will be for racing only.
I always had good pressure and flow including through a front cooler with the SC pump.
2007 911 Turbo - Not a toy
1985 911 Cab - Wife's toy
1982 911 3.2 Indiash Rot Track Supercharged track toy
1978 911 3.0 Lichtbau toy "Gretchen"
1971 911 Targa S backroad toy
Old 09-12-2008, 04:41 PM
Wer bremst verliert
JohnJL's Avatar
Here's a link showing whats involved with fitting a non-SC pump (in this case a GT3) into a 7R case. Dont forget you'll need different sized pump-to-intermediate shaft-extensions for different pumps. And different sump pans. And the GT3 sump pan doesnt have a drain plug?!?
GT3 Oil Pump Into 3.0SC Case
Old 09-12-2008, 04:46 PM
Try not, Do or Do not
Henry Schmidt's Avatar
The Burn_Bros sump cover is one alternative.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 09-12-2008, 08:41 PM
I've got one of those cool burns bros. sump cover that henry is referring to. For sale if anyone wants it.
Tom Ching
69 911E
Old 09-12-2008, 11:00 PM
the Turbo 3.3 oil pump are good?
Old 09-18-2008, 09:36 AM
Those are simply excellent!!
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 09-18-2008, 10:35 AM
YTNUKLR's Avatar
The 3.3 pump is my favorite, truth be told
I have a 3.3 Turbo pump that was just rebuilt by Supertec. Like new.
kindersport@gmail.com if interested
Scott Kinder
Old 09-18-2008, 06:16 PM
This is a great pump with one issue. This style pump uses a sump screen that is rare and NLA through Porsche. The last time I had a pump like this one we were forced to scavenge a late attached screen style pick up from a damaged pump. I hope you have the sump screen in your possession before you plan on using this pump.
Henry Schmidt
Ph: 760-728-3062
Old 09-18-2008, 06:31 PM
