jet settings on 2,2s weber conversion
Hi,
I am a new member with 1968 911 from Bavaria/Germany. The engine is rebuilt to 2.2 s specifications and weber ida carbs. The ignition system is set up correctly and all wires are new. Now I am looking for a recommendation for the correct jet settings. Can anybody help? Thanks a lot and best regards Philipp http://forums.pelicanparts.com/uploa...1221471617.jpg |
some more details:
displacement: 2.2 l compression: 1 : 10.5 911 S Camshafts standard exhaust standart air filter housing with K&N air cleaner standard single plug CDI ignition from 1970 911S manifolds: 35mm (cylinders site / 40mm carb site) altitude: 300m above sea level car will be used for road use |
Phillipp,
Wilkommen auf der Forum. Here is a thread to get you started, if you click on "search" you will find many more. Richard Parr at PMO published the original guide to fitting Weber 40s to a 2,2S. It is here in the archives. http://forums.pelicanparts.com/showthread.php?t=67074&highlight=weber+jet+setting s |
| All times are GMT -8. The time now is 10:45 AM. |
