kodioneill's Avatar
ring compressor redux
ok, what style ring compressor will work installing the cylinders over the pistons?
i have the pliers/band type and cannot install the center cylinder on each bank because you cannot remove it (the band) because of interference from the head studs.
1974 sahara beige 911 targa
1982 chiffon 911sc
1985 prussian blue metallic carrera
Old 10-02-2008, 01:46 AM
Manassas, VA
lucittm's Avatar
I used a Porsche hose clamp (the ones without the little slots cut through) and it worked like a charm. You have to be careful with the ring ends and keep the screw mechanism from scratching the pistons.
Spread a little motor oil on the inside of the clamp. Place the hose clamp over the rings and tighten the clamp just enough to get the rings into the grooves. Watch the bottom ring, it's pretty stiff. Wiggle the piston from side to side and it will go up into the cylinder as the clamp slides off the rings. Unscrew the clamp fully and remove it.
Good Luck,
Mark
1991 964 Polar Silver Metallic Turbo Coupe
Old 10-02-2008, 04:30 AM
304065's Avatar
Some tips on using HAZET ring compressor Nr. 794U-3
'66 911 #304065 Irischgruen
‘96 993 Carrera 2 Polarsilber
'81 R65
Ex-'88 Carrera (Sold 3/29/02)
Old 10-02-2008, 05:11 AM
