-   -   Andial Twin plug conversion for SC (http://forums.pelicanparts.com/911-engine-rebuilding-forum/431763-andial-twin-plug-conversion-sc.html)
matty74 09-22-2008 03:36 PM
Anyone done a twin plug conversion on an sc motor with the Andial distributor kit??
What kind of cost AM I looking at for the andial kit??
Steve@Rennsport 09-22-2008 06:45 PM
Matt,
The Andial kit is primarily for Motronic-equipped cars.
There are three ways to install twin-ignition on an SC:
1) Use 3.6 dual-distributor modified with an SC internal trigger. The crank gear muste be changed to the 3.6 one
2) Install an RSR type distributor. These are available in CCW versions so the crank gear doesn't have to be changed.
3) Install a distributor-less, coil pack system. I don't recommend this option but its cheap.
Henry Schmidt 09-22-2008 08:25 PM
Another option. Perhaps the best aftermarket distributor available.
http://forums.pelicanparts.com/uploa...1222140141.jpg
http://forums.pelicanparts.com/uploa...1222140156.jpg
http://forums.pelicanparts.com/uploa...1222140194.jpg
http://forums.pelicanparts.com/uploa...1222140284.jpg
euro911sc 09-22-2008 08:43 PM
Are you talking about taking an SC dist. and modifying it to use the Andial cap adapter and twin plug rotor? If so, and Steve can easily correct me, the dist. shaft needs to be machined and then you need the adapter. You may also need to have it re-curved to suit your application. After that you need to get twin sparks requiring, and this is where my knowledge runs thin, two CDI's and coils or equivalent.
For pics see this thread of the one I have sitting on the shelf (shameless FS plug):
http://forums.pelicanparts.com/porsche-911-used-parts-sale-wanted/397799-twin-plug-distributor-modified-sc-version.html?highlight=distributor
Enjoy!
-Michael
Henry Schmidt 09-23-2008 05:22 AM
Old school, it worded ok but why use a stone age option when Supertec makes a piece of art for a few pennies more.
These are available for all 911 engine configurations including early cases.
http://forums.pelicanparts.com/uploa...1222172366.jpg
http://forums.pelicanparts.com/uploa...1222172380.jpg
http://forums.pelicanparts.com/uploa...1222172452.jpg
http://forums.pelicanparts.com/uploa...1222172475.jpg
Tom '74 911 09-23-2008 08:06 AM
Steve -
Just curious why you're not a fan of this type of system.
Thanks,
Tom
kenikh 09-23-2008 08:49 AM
Originally Posted by Tom '74 911 (Post 4196476)
Steve -
Thanks,
Tom
Plug fouling from narrow spark plug gaps.
Tom '74 911 09-23-2008 09:01 AM
I thought the benefit of the coil pack systems was that they could throw a lot of specifically timed voltage at the plugs? If this were so, couldn't you widen the gaps?
Personal disclaimer - I know only enough to know that I know nothing about all this!
Thanks,
Tom
edit - I think aesthetically, the 12 plug distributers are beautiful. I only ask. . . to find out the answer!
Steve@Rennsport 09-23-2008 09:25 AM
Thanks,
Tom
Kenik is corrrrrrect,....:) :)
Their performance capabilites are wildly oversold and they do not measure up on MFI or carbureted engines where fuel mixtures are less than ideal. Further, they cannot support the wide plug gaps necessary for best drivability and power.
Tom '74 911 09-23-2008 09:28 AM
That's interesting to know. Are there any applications where they would be a good fit? What about a non carb'd or MFI motor?
Thanks,
Tom
dan67 09-24-2008 05:55 AM
hallo!, mmm finally...which the best (but affordable) twin plug sistem (i have Marelli cap+rotor)
euro911sc 09-24-2008 07:05 AM
Henry's peice is certainly a top product. No argument there! I would have one if I could afford it.
Best regards,
Michael
Henry Schmidt 09-24-2008 07:13 AM
If you have a cap and rotor our GenII dist. (custom built to suit your engine) would cost you $ 1770.
If you have a rebuildable 3.0 or equivalent dist. take off another $200.
Not the cheapest but what great option ever is?
dan67 09-24-2008 10:57 PM
hi henry, yes the twin Plug is "THE OPTION" for 911, but the price for various sistems (non original Magneti Marelli or Bosch) range 1500/3000 USD
matty74 09-25-2008 01:26 AM
I'll eventually buy one of Henrys gizmo's
Henry Schmidt 09-25-2008 05:51 AM
Because you addressed me by name I would love to respond to your comment but I'm not certain what point you are making.
sand_man 09-25-2008 07:02 AM
Not to detract from the Supertec dizzy in any way, what-so-ever, as you can't go wrong with it, but JB Racing also has a dizzy. I throw it out there just so that all of your options are in one place. Here is my thread in the turbo forum, with some pictures:
http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/413780-cdi-coilpack-ignition-options.html
Here is a link to JB Racing...scroll down:
http://www.jbracing.com/eng_porsche.php
