Eye of the Toiger
matty74's Avatar
Andial Twin plug conversion for SC
Anyone done a twin plug conversion on an sc motor with the Andial distributor kit??
What kind of cost AM I looking at for the andial kit??
http://www.aircooled.com.au
1973 911 RSR clone powered by 77 3.0 turbo
Old 09-22-2008, 03:36 PM
Matt,
The Andial kit is primarily for Motronic-equipped cars.
There are three ways to install twin-ignition on an SC:
1) Use 3.6 dual-distributor modified with an SC internal trigger. The crank gear muste be changed to the 3.6 one
2) Install an RSR type distributor. These are available in CCW versions so the crank gear doesn't have to be changed.
3) Install a distributor-less, coil pack system. I don't recommend this option but its cheap.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 09-22-2008, 06:45 PM
Try not, Do or Do not
Henry Schmidt's Avatar
Another option. Perhaps the best aftermarket distributor available.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 09-22-2008, 08:25 PM
Less brakes, more gas!
euro911sc's Avatar
Are you talking about taking an SC dist. and modifying it to use the Andial cap adapter and twin plug rotor? If so, and Steve can easily correct me, the dist. shaft needs to be machined and then you need the adapter. You may also need to have it re-curved to suit your application. After that you need to get twin sparks requiring, and this is where my knowledge runs thin, two CDI's and coils or equivalent.
For pics see this thread of the one I have sitting on the shelf (shameless FS plug):
Twin Plug Distributor: Modified SC Version
Enjoy!
-Michael
Michael
'82 Euro SC 'Track Rat' 22/29 Hollows, 22/22 Tarrets, Full ERPB F/R, Rennline Tri Brace, Glass bumpers, Pro 2000's, 5 pts, blah blah blah
'13 Cayenne GTS
Old 09-22-2008, 08:43 PM
Old school, it worded ok but why use a stone age option when Supertec makes a piece of art for a few pennies more.
These are available for all 911 engine configurations including early cases.
Henry Schmidt
Ph: 760-728-3062
Old 09-23-2008, 05:22 AM
Tom '74 911's Avatar
Steve -
Just curious why you're not a fan of this type of system.
Thanks,
Tom
'74 911 Red Sunroof Coupe, 3.6L, etc...
'76 912 Yellow SPEC 911/911CUP
Old 09-23-2008, 08:06 AM
3 restos WIP = psycho
kenikh's Avatar
Originally Posted by Tom '74 911 View Post
Steve -
Thanks,
Tom
Plug fouling from narrow spark plug gaps.
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 09-23-2008, 08:49 AM
I thought the benefit of the coil pack systems was that they could throw a lot of specifically timed voltage at the plugs? If this were so, couldn't you widen the gaps?
Personal disclaimer - I know only enough to know that I know nothing about all this!
Thanks,
Tom
edit - I think aesthetically, the 12 plug distributers are beautiful. I only ask. . . to find out the answer!
Old 09-23-2008, 09:01 AM
Thanks,
Tom
Kenik is corrrrrrect,....
Their performance capabilites are wildly oversold and they do not measure up on MFI or carbureted engines where fuel mixtures are less than ideal. Further, they cannot support the wide plug gaps necessary for best drivability and power.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
Old 09-23-2008, 09:25 AM
That's interesting to know. Are there any applications where they would be a good fit? What about a non carb'd or MFI motor?
Thanks,
Tom
Old 09-23-2008, 09:28 AM
hallo!, mmm finally...which the best (but affordable) twin plug sistem (i have Marelli cap+rotor)
Old 09-24-2008, 05:55 AM
euro911sc's Avatar
Henry's peice is certainly a top product. No argument there! I would have one if I could afford it.
Best regards,
Michael
Michael
'13 Cayenne GTS
Old 09-24-2008, 07:05 AM
If you have a cap and rotor our GenII dist. (custom built to suit your engine) would cost you $ 1770.
If you have a rebuildable 3.0 or equivalent dist. take off another $200.
Not the cheapest but what great option ever is?
Henry Schmidt
Ph: 760-728-3062
Old 09-24-2008, 07:13 AM
hi henry, yes the twin Plug is "THE OPTION" for 911, but the price for various sistems (non original Magneti Marelli or Bosch) range 1500/3000 USD
Old 09-24-2008, 10:57 PM
Eye of the Toiger
matty74's Avatar
I'll eventually buy one of Henrys gizmo's
Old 09-25-2008, 01:26 AM
Because you addressed me by name I would love to respond to your comment but I'm not certain what point you are making.
Henry Schmidt
Ph: 760-728-3062
Old 09-25-2008, 05:51 AM
resident samsquamch
sand_man's Avatar
Not to detract from the Supertec dizzy in any way, what-so-ever, as you can't go wrong with it, but JB Racing also has a dizzy. I throw it out there just so that all of your options are in one place. Here is my thread in the turbo forum, with some pictures:
CDI coilpack ignition options???
Here is a link to JB Racing...scroll down:
http://www.jbracing.com/eng_porsche.php
-jeff
Old 09-25-2008, 07:02 AM
