idc1873
coxy's Avatar
top end rebuild, specialist tools
Planning a top end rebuild soon.
I have most of the tools/equipment needed for a engine rebuild but what special tools/equipment will i require on my 3.2 and where is the best place to source parts and tools from. Got a lot of reading up to do yet. Any advise, hints/tips, web links appreciated
Old 09-23-2008, 12:14 AM
Off the top of my head, after mine a year ago:
Engine stand adapter to fit Porsche flat 6
Cam holding tool for camshaft removal/ cam timing adjustment
Z block and dial indicator for cam timing
Propane torch to heat all the rusted studs, nuts from the exhaust manifolds and cylinder head barrel nuts
A sacrificial set of easy-outs for the barrel nuts you will strip trying to remove
Copy of How to Rebuild and Modify Porsche 911 Engines- available here at Pelican
This is assuming you are farming out the machine work...
Good Luck!
Mackskibum aka Dave Austin
'66 911 Work In Progress (#303734)
'85 911 Carrera
06 325XI
'05 Envoy XL SLT
Old 09-23-2008, 07:20 AM
MBEngineering's Avatar
HI coxy
give me a ring 015395 67959 I may be able to help you out!!
regards mike
Regards mike
1983 911 SC sport, 1982 mini city
Old 09-23-2008, 11:00 AM
