-   -   Which Engine Tin Bolts? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/432100-engine-tin-bolts.html)
lucittm 09-24-2008 08:30 AM
In preparation for reassembly of my 1991 turbo engine, I noticed that there are two different types of OEM 6 x 12mm engine tin bolts with included washers:
1. One set of bolts is head stamped KAMAX.
2. One set of bolts that is head stamped BOESNER and seems to have the threads squeezed into a triangular pattern in order to provide a retention mechanism.
My question is - which bolts go where? I would think one type for use in aluminum in the engine and one for steel in the tins.
I think the replacement bolts sold by Pelican do not have the OEM head stamp, but if they are different specifications, there should be different part numbers. I just can't tell which is which.
Does anyone have the P/N's for each type?
Thanks,
Mark
304065 09-24-2008 08:47 AM
The BOESNER headmark is a patented triple locking screw. Part number is
999 143 004 08
Pelican sells them for $2.25 each. That is the price of the patent.
http://forums.pelicanparts.com/uploa...1222271380.jpg
Download the legal version of PET and look at illustration 105-07, you will see which are locking and which are conventional 999 075 039 02. These probably are the ones with the headmark KAMAX. I would show you this except PET cannot be copied. Anyway you want the page with the engine tin on it.
Good luck!
lucittm 09-24-2008 09:53 AM
Mystery solved! I found the illustrations on PET pages 105-07 and 105-12.
I could not have done it without your reference to the part numbers, nice work.
Thanks,
Mark
911 tweaks 09-25-2008 05:24 AM
Hi John... a few q's on this subject if you can help out here:
1. p/n 999 143 004 08 this is the BOESNER fastener... how many needed for an sc's tin ??
2. p/n 999 075 039 02 pelican says this is a m6x12 fastener... 16 req'd... is this a std m6x12 bolt w/ hex head ?? Also, does this 'bolt' need any washers ie flat and or lock ??
3. is it possible you can post pics of those 2 pet pgs or some how explain where these 2 fasteners are used ??
Thanks again for your always sharp & complete help to pelicans !!! :-)
Bob
