| Manassas, VA |
				Which Engine Tin Bolts?
			In preparation for reassembly of my 1991 turbo engine, I noticed that there are two different types of OEM 6 x 12mm engine tin bolts with included washers: 1. One set of bolts is head stamped KAMAX. 2. One set of bolts that is head stamped BOESNER and seems to have the threads squeezed into a triangular pattern in order to provide a retention mechanism. My question is - which bolts go where? I would think one type for use in aluminum in the engine and one for steel in the tins. I think the replacement bolts sold by Pelican do not have the OEM head stamp, but if they are different specifications, there should be different part numbers. I just can't tell which is which. Does anyone have the P/N's for each type? Thanks, Mark
				__________________ 1991 964 Polar Silver Metallic Turbo Coupe | ||
|  09-24-2008, 07:30 AM |
| Moderator Join Date: Dec 2001
			The BOESNER headmark is a patented triple locking screw.  Part number is 999 143 004 08 Pelican sells them for $2.25 each. That is the price of the patent.  Download the legal version of PET and look at illustration 105-07, you will see which are locking and which are conventional 999 075 039 02. These probably are the ones with the headmark KAMAX. I would show you this except PET cannot be copied. Anyway you want the page with the engine tin on it. Good luck!
				__________________ '66 911 #304065 Irischgruen ‘96 993 Carrera 2 Polarsilber '81 R65 Ex-'71 911 PCA C-Stock Club Racer #806 (Sold 5/15/13) Ex-'88 Carrera (Sold 3/29/02) Ex-'91 Carrera 2 Cabriolet (Sold 8/20/04) Ex-'89 944 Turbo S (Sold 8/21/20) Last edited by 304065; 09-24-2008 at 07:50 AM.. | ||
|  09-24-2008, 07:47 AM |
| Manassas, VA |
			Mystery solved!  I found the illustrations on PET pages 105-07 and 105-12.   I could not have done it without your reference to the part numbers, nice work. Thanks, Mark
|  09-24-2008, 08:53 AM |
| Registered Join Date: Apr 2006 Location: northeast
			Hi John... a few q's on this subject if you can help out here: 1. p/n 999 143 004 08 this is the BOESNER fastener... how many needed for an sc's tin ?? 2. p/n 999 075 039 02 pelican says this is a m6x12 fastener... 16 req'd... is this a std m6x12 bolt w/ hex head ?? Also, does this 'bolt' need any washers ie flat and or lock ?? 3. is it possible you can post pics of those 2 pet pgs or some how explain where these 2 fasteners are used ?? Thanks again for your always sharp & complete help to pelicans !!! :-) Bob
				__________________ I live for 911 tweaks... | ||
|  09-25-2008, 04:24 AM |
