blau911's Avatar
changing non mfi 911S cams into 911S MFI cams
Guys,
I am getting ready to put together a 2.4S motor with MFI. The only problem left before going ahead and putting it together is that I have a set of non mfi 911S cams and need a set of MFI 911S cams.
I spoke to a sales rep at Webcam today, and she advised that Webcam can simply weld on the extra drive so it will work for the MFI. Price is only $150 which is a lot cheaper than buying new ones. Has anyone done this? Is they any downside?
Old 10-07-2008, 10:04 AM
Warren Hall Student
Bobboloo's Avatar
Welding works but why not just tap them and bolt on an extension?
Bobby
_____In memoriam_____
Warren Hall 1950 - 2008
_____"Early_S_Man"_____
Old 10-07-2008, 11:01 AM
sww914's Avatar
It does need to be timed AFAIK, it may be worth it to just pay the guy. I wouldn't know where to set it?
Old 10-07-2008, 07:50 PM
BURN-BROS's Avatar
Camgrinder may sell you a bung that bolts on to the end of your cam. you will need access to a lathe to machine a pocket and tap two holes. No timing of the bung is necessary, that is done with the pulleys. I have converted a couple of cams to mfi with no problems.
Aaron. F.S. 1965 Solex engine w carbs/cleaner
Burnham Performance
https://www.instagram.com/burnhamperformance/
Old 10-07-2008, 08:51 PM
blau911's Avatar
Don't have access to a lathe. Considering the amount $125-150), I would just assume let a seasoned cam specialist do the work. Thanks for the input.
Old 10-07-2008, 11:21 PM
