BOW DOWN to the might of big bore MFI!!!
I have received my completely rebuilt and bored, big bore MFI stacks and TBs. While I do get some joy in soliciting jealous responses ;), I think everyone here would really like to get a close look at some fantastic work.
These TBs are the work of Aaron B, better known as "Burn-Bros" on this forum and of the twin plug dizzy fame. For context, this was an R&D project so don’t ask me if he'll do this kind of work for you, how much it cost or anything of the like. I want to give him credit, but at this point he wanted me to let everyone know up front that he isn't interested in soliciting work at this juncture. Basic details. This MFI is for a 2.3L, modern take on a first generation 911ST motor. You've all seen my specs. You've also seen the heads, which were a major driver for the unusual bore spec for a motor this small. By unusual, I mean that these stacks taper from 52mm at the top, down to ~39mm at the throttle plates, through the irregular ports. The bottom line is that the entire intake tract acts like a tapered venturi from the top of the MFI, all the way to the valve surface. Air velocity of this set up is entirely against the laws of intuition - and equally eye popping. Take special care to notice the irregular contours of the bottom of the TBs into the intake head bores. My heads have an irregular, custom shape and Aaron took the time to match taper these by hand for a perfect transition. That said, time for the show! http://i25.photobucket.com/albums/c7...I/IMG_0750.jpg http://i25.photobucket.com/albums/c7...I/IMG_0749.jpg http://i25.photobucket.com/albums/c7...I/IMG_0734.jpg http://i25.photobucket.com/albums/c7...I/IMG_0735.jpg http://i25.photobucket.com/albums/c7...I/IMG_0740.jpg http://i25.photobucket.com/albums/c7...I/IMG_0741.jpg http://i25.photobucket.com/albums/c7...I/IMG_0739.jpg The TB surface. http://i25.photobucket.com/albums/c7...n/IMG_0496.jpg The port. |
OH DAMN, there goes the bar up another notch.:D
Very nice, I look forward to seeing more of this one. Bob |
Thanks, Bob! I am hoping you'll get to see it in Cambria.
Very, very cool there, Kenik. Can't wait to hear those things gulping vast quantities air, feeding that screaming little 2.3. That is going to be so freakin' cool...
Don't get too close, I might suck all of the air out of your wussy little 36mm stacks. ;)
BTW, you will need one stout bottom end. That thing will not run out of air till 9500.
My compliments to Aaron for some really nice work!
Those will match the heads very nicely,...:) :) :) Well done. |
Not to mention valve train.:eek:
Coolness. Questions:
The matching of the bottom of the TB is to eliminate flow restrictions? Is there an anti-reversion step there or is it fair? The big intake trumpets, is that because the stacks were tapered and the regular stuff is too small? I see leftover bluing on the flange, how did he clearance these, do you know the technique? Milling machine or CNC, you say "by hand" I assume that means with his hands on a milling machine, not a die grinder. Great stuff! |
John, there is a reversion ledge. I'd like to hear the rationale/theory behind it. I assume it breaks up the eeversion wave to keep the intake charge from fartin (too much) back up the stacks on high overlap cams. Steve, they're your heads...what are your thoughts? You are 100% correct on the trumpets.
Also, the throttle bodies are 41mm/39mm. Throttle plates are 41mm. Quote:
Top part of the throttle body is done on a manual mill to establish the port size and location. The rest has to be done with a die grinder since a mill can only bore linearly. |
O man...
I am absolutely so impatient to see how this runs..its beautiful work for sure.. Tapered inlet tracts on various other engines of my long -in-the -tooth acquaintance sometimes work spectacularly well: sometimes not. But I have no tips to offer as to why this might be.. Or, more pertinently, why the factory reduced the taper from the first 2.0L MFI S to the 2.2S.. Steve, any update on those tiny valve 2.0L FIA heads please? The pistons are designed: I'm expecting to see some CAD files soon to send you.. Real Metal will take about 8 weeks unfortunately.. Kind regards david |
Hi David,
As soon as I get a moment, I'll flow one here and see what may be possible,..:) |
Wow those look amazingly similar to a set done at Supertec.
I wonder why?;) Cheers |
The bolt pattern is wider than the ones Porsche used on the their stacks so slotting and custom hardware is required. The Porsche stacks use the same bolt pattern as the Weber velocity stacks. Note the slotting on the stack where the trumpet mounts. The other slotting (4 cut outs) on the stack where the air filter mounts is consistant with mounting of PMO air filters. http://forums.pelicanparts.com/uploa...1224970364.jpg |
kenik,
That is pure MFI porn. My mere E setup looks kind of wimpy now! thanks for that......now I will seek therapy to control my intake envy! Al |
LOL. At least yours is closer to running than mine!
I can see this playing out with some sort of cartoon:
Awwww. What a cuuuute little 2.3liter motor. Hey there, little guy, what do you want to be when you grow up?!?! GRAGEWWSDFLASDFLKASGRAAAGRHHHHAAR!!!! (As it bites your frickin' arm off.) ROTFLMAO :D :D :D Good stuff, Brother ... good stuff. |
Currently trying to figure out how the hell to have the car done by May. I'll let you all know if the project plan proves it reasonable.
good show Kenik. Are you going to be able to run those buckets? I thought Henry told me you can't fit the hardware/socket in there.
Henry (or is it Aaron ;) ) just did me a very similar set-up, based on a totally crapped out '69E set-up (very corroded). Man they are so light weight! Stack; 52- dropping down to 41.5, then the TB from 41.5->40 . Thanks again Aaron and Henry!! |
Henry/Supertec does need acknowledgment for Kenik's stacks and throttles as I would not have had the proper parts and equipment to do them to the caliber that they are. |
Let's be totally transparent. There are numerous peeps that need love on this effort:
Henry Schmidt, Steve Weiner, Aaron Burnham and Bernie Buschen, to start. Henry has more parts and know how in my motor than I could list here. When I visited him and Aaron in Fallrook, CA, I knew these guys were as good as it gets. Aaron is a whirlwind of activity that no one can keep up with; a brain with the ability to make it happen. Steve, what can you say - the guy is so selfless, it's scary and he loves this stuff almost to a fault - potentially the nicest human on the planet. This motor bears his indelible stamp. Bernie, most of you guys don't know - he is under the radar, but is my go to guy for work I won't do myself. Considering the stable of RGrupper cars he handles, not to mention the multiple 935s he manages, I am lucky to have the access I do. He's the tie breaker when everyone else doesn't agree. :) Oh yeah, Charles Navarro and John Dougherty have also had more impact on my project than I can adequately credit. These guys are friggin' geniuses, as well. I run Nickies and Dougherty cams for a reason - there is nothing better. PERIOD. Oh and Scott Kinder...there would be no motor without Scott. That '69S motor was they key. All of these guys have been bottomless wells of knowledege, sounding boards for ideas, resources for work and parts. Most importantly, friends who I trust deeply. I consider my motor the collaboration of one of the finest virtual race teams someone could ever assemble. I am certain that Marco's commentary will prove to the most salient of all. :D Cheers. |
http://i25.photobucket.com/albums/c7...kaman/rods.jpg |
| All times are GMT -8. The time now is 09:40 PM. |
