3 restos WIP = psycho
BOW DOWN to the might of big bore MFI!!!
I have received my completely rebuilt and bored, big bore MFI stacks and TBs. While I do get some joy in soliciting jealous responses
, I think everyone here would really like to get a close look at some fantastic work.These TBs are the work of Aaron B, better known as "Burn-Bros" on this forum and of the twin plug dizzy fame. For context, this was an R&D project so don’t ask me if he'll do this kind of work for you, how much it cost or anything of the like. I want to give him credit, but at this point he wanted me to let everyone know up front that he isn't interested in soliciting work at this juncture. Basic details. This MFI is for a 2.3L, modern take on a first generation 911ST motor. You've all seen my specs. You've also seen the heads, which were a major driver for the unusual bore spec for a motor this small. By unusual, I mean that these stacks taper from 52mm at the top, down to ~39mm at the throttle plates, through the irregular ports. The bottom line is that the entire intake tract acts like a tapered venturi from the top of the MFI, all the way to the valve surface. Air velocity of this set up is entirely against the laws of intuition - and equally eye popping. Take special care to notice the irregular contours of the bottom of the TBs into the intake head bores. My heads have an irregular, custom shape and Aaron took the time to match taper these by hand for a perfect transition. That said, time for the show! ![]() ![]() ![]() ![]() ![]() ![]() ![]() The TB surface. ![]() The port.
- 1965 911 - 1969 911S - 1980 911SC Targa - 1979 930 Last edited by kenikh; 10-24-2008 at 10:51 AM.. |
The custom spun aluminum trumpets:
- 1965 911 - 1969 911S - 1980 911SC Targa - 1979 930 |
OH DAMN, there goes the bar up another notch.
![]() Very nice, I look forward to seeing more of this one. Bob |
Thanks, Bob! I am hoping you'll get to see it in Cambria.
Very, very cool there, Kenik. Can't wait to hear those things gulping vast quantities air, feeding that screaming little 2.3. That is going to be so freakin' cool...
Jeff '72 911T 3.0 MFI '93 Ducati 900 Super Sport "God invented whiskey so the Irish wouldn't rule the world" |
Don't get too close, I might suck all of the air out of your wussy little 36mm stacks.
BTW, you will need one stout bottom end. That thing will not run out of air till 9500.
My compliments to Aaron for some really nice work!
Those will match the heads very nicely,... ![]() Well done.
Steve Weiner Rennsport Systems Portland Oregon (503) 244-0990 porsche@rennsportsystems.com www.rennsportsystems.com |
Not to mention valve train.
Forged rockers, Supertec springs, titanium retainers. BTW, I am only looking for 8200RPM on run out with this motor.
That's o.k., I'll just choke it with that massive "clearing its throat" cloud. I already turned your Light Ivory car brown, now I'll make those shiny aluminum stacks look like weathered brass...
Coolness. Questions:
The matching of the bottom of the TB is to eliminate flow restrictions? Is there an anti-reversion step there or is it fair? The big intake trumpets, is that because the stacks were tapered and the regular stuff is too small? I see leftover bluing on the flange, how did he clearance these, do you know the technique? Milling machine or CNC, you say "by hand" I assume that means with his hands on a milling machine, not a die grinder. Great stuff!
'66 911 #304065 Irischgruen ‘96 993 Carrera 2 Polarsilber '81 R65 Ex-'71 911 PCA C-Stock Club Racer #806 (Sold 5/15/13) Ex-'88 Carrera (Sold 3/29/02) Ex-'91 Carrera 2 Cabriolet (Sold 8/20/04) Ex-'89 944 Turbo S (Sold 8/21/20) |
John, there is a reversion ledge. I'd like to hear the rationale/theory behind it. I assume it breaks up the eeversion wave to keep the intake charge from fartin (too much) back up the stacks on high overlap cams. Steve, they're your heads...what are your thoughts? You are 100% correct on the trumpets.
The throttle body profile should be slightly smaller than the intake port. This step between the throttle and head should provide some reversion protection. Quote:
Also, the throttle bodies are 41mm/39mm. Throttle plates are 41mm. Quote:
![]() Top part of the throttle body is done on a manual mill to establish the port size and location. The rest has to be done with a die grinder since a mill can only bore linearly.
Aaron. F.S. 1965 Solex engine w carbs/cleanerBurnham Performance https://www.instagram.com/burnhamperformance/ Last edited by BURN-BROS; 10-24-2008 at 07:00 PM.. |
Thanks Steve, hope all is well.
Aaron. F.S. 1965 Solex engine w carbs/cleanerBurnham Performance https://www.instagram.com/burnhamperformance/ |
O man...
I am absolutely so impatient to see how this runs..its beautiful work for sure.. Tapered inlet tracts on various other engines of my long -in-the -tooth acquaintance sometimes work spectacularly well: sometimes not. But I have no tips to offer as to why this might be.. Or, more pertinently, why the factory reduced the taper from the first 2.0L MFI S to the 2.2S.. Steve, any update on those tiny valve 2.0L FIA heads please? The pistons are designed: I'm expecting to see some CAD files soon to send you.. Real Metal will take about 8 weeks unfortunately.. Kind regards david |
Hi David,
As soon as I get a moment, I'll flow one here and see what may be possible,..
Try not, Do or Do not
Wow those look amazingly similar to a set done at Supertec.
I wonder why? ![]() Cheers
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net |
These beautiful velocity stacks a available from PMO. They were designed to fit the PMO 50 mm carburetors.
The bolt pattern is wider than the ones Porsche used on the their stacks so slotting and custom hardware is required. The Porsche stacks use the same bolt pattern as the Weber velocity stacks. Note the slotting on the stack where the trumpet mounts. The other slotting (4 cut outs) on the stack where the air filter mounts is consistant with mounting of PMO air filters.
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net Last edited by Henry Schmidt; 10-25-2008 at 02:37 PM.. |
