kodioneill's Avatar
1973 cis tensioner
what is the "special adapter" that wayne talks about in his book for the cam oil line size?
1974 sahara beige 911 targa
1982 chiffon 911sc
1985 prussian blue metallic carrera
Old 11-18-2008, 09:18 AM
304065's Avatar
Search here for "oil line restrictor"- when the factory went to a larger oil pump with the 964 they put restrictors in the cam oil lines to limit the flow. Some suggest that this reduces foaming of the oil and increases oil pressure, I happen to like the originals.
'66 911 #304065 Irischgruen
‘96 993 Carrera 2 Polarsilber
'81 R65
Ex-'88 Carrera (Sold 3/29/02)
Old 11-18-2008, 09:34 AM
kodioneill's Avatar
thanks john i should have been more discript. i'm talking about the r/s line where it meets up with the case. on 1974 and up there is a oil sender there. there isn't on the 1973.
thanks
1982 chiffon 911sc
Old 11-18-2008, 09:40 AM
3.2 CAB's Avatar
On your other post about this issue, the block that is in the"adapter kit" is the same block as the later engines used for the oil sender location. Check the other post for the complete list of parts needed for the right side, on your 73'. Good luck!! Tony.
84' Steelslantnose Cab.
1953 Dodge B-4-B-108" 90,127 miles
1953 Dodge B-4-C-116" 58,146 miles
1954 Dodge C-1-B8-108" 241V8 POLY
1973 Roadrunner 440-SIX-PACK*
1986 F-250 Super Cab-460 V8 tow
Newest additions-
Matching numbers 1973 340 Road Runner!!
1948 Dodge B-1-F-152" 1-1/2 ton Dump body, 39,690 miles
others...
Old 11-18-2008, 10:58 AM
