MBEngineering's Avatar
HI Andy
is this any good:
for your educational purposes only.
regards mike
Regards mike
1983 911 SC sport, 1982 mini city
Old 12-01-2008, 05:40 AM
356RS's Avatar
Hi Andy, Sounds like a fun engine. Checking line-bore with your old bearings might not give you the correct answer. Your old bearing have been worn in on the misaligned bearing bores and lets the crank turn free. New bearings might show a different story. I would hate to see you have problems during assembly. The mains looked good on my 7R case also but I had Walt at CE surface the case half's flat and then re line-bore standard. A little more work but now it's straight down the middle.
Mark Jung
Bend, OR
MFI Werks.com
Old 12-01-2008, 08:15 AM
abit off center
cgarr's Avatar
When you bore the case mains you also need to do the layshaft bore and alignment and rear seal area:
______________________
Craig
G2Performance
Old 12-01-2008, 08:25 AM
Thanks mike, two 4.5 mm drills and if I can remember how to read a micrometer all wiil be well ( Joke)
Good advice to ensure all relevant bores are machined, thanks.
Old 12-02-2008, 04:20 AM
up-fixing der car(ma)
YTNUKLR's Avatar
Send a message via AIM to YTNUKLR
Originally Posted by MBEngineering View Post
HI Andy
is this any good:
regards mike
Mike ,
What does the book say about when the intermediate shaft is a "1"? I can't see the measurement from the photo.
Thanks!
Scott
Scott Kinder
kindersport @ gmail.com
Old 12-02-2008, 06:29 PM
HI Scott
there you go;
regards mike
Regards mike
Old 12-03-2008, 12:47 AM
YTNUKLR's Avatar
Thank you very much, Mike.
Scott Kinder
Old 12-03-2008, 12:49 AM
