hipdoc's Avatar
mech fuel distributor
I've got a 73' 911 E and rebuilding the engine. I use to run a pair of Weber carb's but I was thinking about going back to the mechanical fuel distributor, but misplaced most of the components, ie, throttle stacks, injectors, and fuel lines. Where should send the distributor to get rebuild and where can I get the missing parts? Is it even worth going back to original fuel system? Thanks, hipdoc
Old 11-28-2008, 08:24 PM
Max Sluiter
Flieger's Avatar
You mean Bosch MFI?
Send the injection pump to Eurometrix or Gus Pfister at Pacific Fuel Injection.
There are others who rebuild pumps and they are listed in the "Ultimate MFI Resources Thread" in the 911 Technical Forum.
Old 11-28-2008, 09:54 PM
Max Sluiter
Flieger's Avatar
The injection pump is much more than a "mechanical fuel distributor"
here is one resource:
Ultimate MFI resources thread
Old 11-28-2008, 10:08 PM
Max Sluiter
Flieger's Avatar
From Pelican tech articles:
Contacts for Injection Pump Service:
Pacific Fuel Injection (Gus Pfister)
Suite B, 153 Utah Av
South San Francisco, CA
Tel. 650-588 8880
Jerry Fairchild Industries (Robert Turner)
5242 Westside Rd
Redding, CA 96001
Tel. 530-241 1592
Walz Diesel Fuel Injection (Norbert Schuller)
Sydney (expensive)
Tel. 02-9755 1422
Eurometrix (throttle body rebuilder)
228 Boston Rd
Groton, MA 01450
Tel. 978- 448 2557 (Matt Blast )
Phil Sumich (throttle body rebuilder)
Brisbane
Tel. 07-3390 8133
Super Tec (throttle body rebuilder)
Tel. 714-429 1863
Old 11-28-2008, 10:10 PM
hipdoc's Avatar
Yes, I meant the Bosch MFI. I have one complete one and another for parts. Do you know where the best place to find the rest of the system to use the MFI? If it's going to be a pricey ordeal, I'm thinking about sticking with the Webers.
Old 11-29-2008, 07:22 AM
Max Sluiter
Flieger's Avatar
To find missing parts, the Early 911S Registry classifieds section, as well as Pelican Parts classifieds are your best choices.
People here: http://www.early911sregistry.org/forum/index.php will sort through eBay and post the most interesting items and the most well documented parts.
Shops like TLG Auto, TRE Motorsport, Supertech, etc. may have parts like those stored in the back room.
Old 11-29-2008, 12:23 PM
