Case/Crank Work Summary
I've been reading a lot of threads this evening. I want to pull things together for my notes on work I'll have done down the road.
Aluminum Case (plan to build a 3.4/3.5 SS track/race motor) 1) Case Boat tail not needed 2) Case Shuffle Pin. only needed for high RPM, so in this case yes. The SuperTec crank is a work of art, but not sure I'll have the budget for that 3) Crank knife edge, did not see a clear consesus on this. 3) Crank cross drill yes 4) Crank polish? lighten? crank plugs?
John Snodgrass 1973 Porsche 911 "Barney" (race car for sale) 2008 Nissan Maxima - Daily Driver 1999 F350 Diesel Crew Cab - Tow Beast 1990 Airstream 36' Land Yacht - Home Away From Home |
Air Medal or two
Polish yes
lighten..if possible (?) plugs - B.A. says never disturb them
D troop 3/5 Air Cav,( Bastard CAV) and 162 Assult Helicopter Co- (Vultures) South of Saigon, U Minh Forest, Delta, and all parts in between |
1)Yessir,..its been worth 10 HP on a 3.4/3.5 for 25+ years as measured on our engine dyno. Thats a must-do for any race engine going over 7K. 2) Engines that will spend time above 7K should be shuffle-pinned. 3) Yes. This is part of an effective windage control system. 4) Yes! Cross-drill the center main to get sufficient oil to the adjacent rod bearings. 5) Each & every crank we do gets magnafluxed, balanced, micro-polished and the oil galley plugs are removed to properly clean out the passages, otherwise you've left all that debris in there. Hope this helps,
Steve Weiner Rennsport Systems Portland Oregon (503) 244-0990 porsche@rennsportsystems.com www.rennsportsystems.com |
