84 911 oil leak
Ever since I replaced head studs on this customers '84' 911, I have a seepage that appears to be from the sealing surface of the cam carrier and cylinder head. This is the number three cylinder. It is also the same cylinder which lost compression due to two broken studs. Do not feel this seepage is from application error. Been back in twice now. Surfaces are clean and flat. Using Loctite 574 sealer. Any help out there? Either within this Forum or some other site that can be recommended? I am new to this Forum. Please any suggestions will be appreciated.
Old 11-29-2008, 05:16 AM
abit off center
cgarr's Avatar
Have you ruled out the rocker arm shafts as the leak?
______________________
Craig
G2Performance
Old 11-29-2008, 05:47 AM
I was not aware this was possible.
Old 11-29-2008, 08:58 AM
Forced Induction Junkie
WERK I's Avatar
Was there any surface damage done to the head and or cylinder surfaces from the two broken studs? If so, were the heads milled to correct?
Dave
'85 930 Factory Special Wishes Flachbau
Werk I Zuffenhausen 3.3l/330BHP Engine with Sonderwunsch Cams, FabSpeed Headers, Kokeln IC, Twin Plugged Electromotive Crankfire, Tial Wastegate(0.8 Bar), K27 Hybrid Turbo, Ruf Twin-tip Muffler, Fikse FM-5's 8&10x17, 8:41 R&P
Old 11-29-2008, 11:22 AM
Max Sluiter
Flieger's Avatar
If you checked the surfaces of the head and cam carrier for flatness with suitable methods (glass plate/granite block, feeler gauge), I would think a rocker arm shaft is leaking.
RSR seals may be all you need to fix the problem.
Old 11-29-2008, 12:27 PM
thank you for your replies. I am going to get this vehicle back this week and put rocker seals in it.
Old 12-01-2008, 04:38 AM
OldTee's Avatar
Make sure the rocker shafts are installed properly. Ie one side of the rocker shavt end flush with the smaller rocker boss. Don't ask me how I know.
Old Tee
all 911s sold
Old 12-01-2008, 05:02 AM
Thanks OldTee, I am familiar with this concern.
Old 12-01-2008, 08:59 AM
