-   -   3.2 engine rebuild, advice welcome (http://forums.pelicanparts.com/911-engine-rebuilding-forum/444328-3-2-engine-rebuild-advice-welcome.html)
coxy 12-03-2008 12:46 AM
Doing a top end rebuild on my 3.2. more advice the better.
Rebuild thread on IB.
http://www.impactbumpers.com/forum/index.php?showtopic=7870&st=0
MBEngineering 12-03-2008 01:11 AM
HI Coxy
your link will not work, as John has LOCKED the forum unless you log in.
top end parts you will need ; gasket set, rings, valve guides (exhaust), timing chains, chain rails,
Poss' parts; exhaust studs, head studs, cylinders/pistons, exhaust valves, intake manifold heat sink/spacers, fuel lines, cam feed pipes, fan belt, plugs, cams/rockers,
all this will depend on the mileage and driving usage of the car, the rings/pistons could be worn out,
http://forums.pelicanparts.com/uploa...1228295303.jpg
http://forums.pelicanparts.com/uploa...1228295329.jpg
I am not saying your rings will look like this, but if it is any where 100,000 miles thay could be.
regards mike
porschenut 12-03-2008 06:34 AM
Best advice I can give is use Wayne's book as a guide.
hcoles 12-04-2008 07:01 PM
+1 - and read and reread, and most importantly follow what it says. Get boxes and good zip lock bags and write down what the parts go to on a card and put in the bag... you think you will remember but you won't...even if you are young and don't have CRS.
