haycait911's Avatar
de-glazing nicasil cylinders - a new approach?
after much reading on this whole issue and a near miss on using a grape hone, I came up with this method.
my cylinders were quite glazed. I wanted to do something but was scared off the grape hone, and a diamond honing shop isn't a possibility here. so here's what I did.
- bought a three stone cylinder hone.
- bought some 180 grit aluminum oxide cloth-backed sandpaper ( same grit material as the recommended grape hone ).
- used a disc sander to bevel the stones on the hone ( for a smaller contact area ).
- tore some strips to fit over the stones.
- glued sandpaper to hones with contact adhesive spray.
- chucked the hone into my drill, oiled the cylinders, and ran the hone on slow speed up and down for about 20-30 seconds.
- changed the sandpaper every 2 cylinders to keep it fresh.
the results are exactly what I was hoping for. the cylinders were previously very polished, now a light cross-hatching is visible, more of a dulling of the surface.
any thoughts? Don.
Old 12-26-2008, 07:01 PM
DCinVA's Avatar
I was intrigued by your creativity, and I was hoping an expert would comment on your approach.
I am no expert but, I have read that honing these cylinders with anything more than a scotch brite pad is a no-no. I hope my recollection is wrong, and I hope this solution works out for you. Hopefully someone more experienced than I have will chime in.
Dave
2014 Cayman S (Awesome car!)
1991 911 Carerra (Semi Refined fun)
1986 911 Carrerra (Raw fun) sold
2001 Boxster S (Refined fun) sold
Old 12-29-2008, 10:58 AM
DCinVA's Avatar
I found a link related to honing cylinders.
do I need to hone this?
Dave
Old 12-30-2008, 08:43 AM
