Chain fence eating turbo
First off, my car is an '87 Carrera 3.2 with a single turbo. After doing the "money shift" and tearing down the motor, I have been trying figure out which rods I have.
I cant find the origin of these rods in my 3.2. I tried Waynes Porsche PET links with no avail. I figured they were 930 rods because I have the flat top pistons for the turbo. Also, is my barrels the stock ones with the part number: 95NZ1.......W16.........A8? TIA, Cory
Cory - turbo'd '87 C3.2 Guards/Blk, 3.4, 7.5:1 CR, 993SS cams, Borg-Warner S366 turbo @ 1.2-1.5 bar, Treadstone full bay IC, 70mm TB, TiAL F46 WG, HKS 1 1/2" BOV, twin 044 pumps, MicroSquirt AMP'd w/GM smart coilpack, Bilstein coilovers, Tramont replica Speedlines (285's rr, 225's frt), Big Reds frt, 993 rr., tower brace, MOMO wheel |
The 3.2 and the 3.3 rods are the same, having a smaller wrist pin then prior rods of the SC. The cylinders can be either Carrera or SC. If there is no head gasket CE ring the cylinders are Carrera. If there is a head gasket relief then they are SC
There were thin copper looking barrel gaskets at the bottom.
That is the base seal for the cylinder. The new ones in the kits are black |
3.2 and 930 rod is the same part, as is the 964 rod.......
Cheers
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
Then, the 964 rods said 964.103.XXX.X followed by the 993.103.XXX.X for the 993's of course. So mine, has the same 930.103. as all the others but none in the PET had the 121.2 R suffix as my rods have. So, I still have just a regular 3.2/3.3 rod?
up-fixing der car(ma)
yes, 3,2/3,3 rod
Scott Kinder kindersport @ gmail.com |
Open up many 3.6 964 motors and in them you will find rods with 930.103.....
Cheers
Ok, thanks Scott
![]() Quote:
