I pulled a customers 912 engine out yesterday to replace the flywheel seal and found that the rear main bearing behind the flywheel was broken. Have any of you ever seen this happen? I have seen spun rear mains and ones that have been pinched by the main bearing dowel pins but I have NEVER seen this. The crank is not broken either. The car came in running fine just leaking alot of oil.
![]() ![]() Dan
Dan 2002 996 C4 Cab w/ Jake Raby 4.0 2024 Tacoma TRD Offroad 4x4 2003 Range Rover HSE |
abit off center
Looks like just the thrust flange broke off, Was there any shims under the flywheel? Maybe someone at one time cranked it down without shims and cracked it?
I have never seen this, Have seen bearings so loose they were chucking back and forth in the case which makes it hard to set the end play.
______________________ Craig G2Performance Twinplug, head work, case savers, rockers arms, etc. |
Air Medal or two
We used to abuse our VW engines ...a little.... LOL and @ high RPM they would break the crankshaft just behind the last main...always.. ! Now technically you have a P. Eng. but the characteristics might be the same,...?
You have a tougher crank and a tougher case but ??? just a guess
162 Assault Helicopter Co,(Vultures ) D troop 3/5 Air Cav. ( Bastard CAV) South of Saigon, U Minh Forest, Delta, and most parts in between. |
cgarr, There was a shim under the flywheel and the end play felt normal. If someone torqued the flywheel with "no" shims it would just make accessive end play. Possibly someone cranked it down with "too" many shims and crushed the bearing.
afterburn 549, The crank is NOT broken. I too have seen that many times in VW motors. All good ideas. Keep them coming. I will know more I guess when the motor gets torn down. (that is if the customer wants us to go that far) He was talking about finding a good used motor instead.
