up-fixing der car(ma)
YTNUKLR's Avatar
Send a message via AIM to YTNUKLR
Why the 12mm Spark Plug?
I saw what seemed like factory 2.5 911S-T Race Heads on Ebay a while back, and the listing stated they were 12mm plugs (both). It seems silly for someone to have welded up the standard 14mm plug so I assume those were factory race heads.
I have also heard that Porsche used 12mm plugs as the secondary plugs in the twin-plugged race engines.
Why is this the case? What is the benefit to running a 12mm spark plug?
Cheers
Scott
Scott Kinder
kindersport @ gmail.com
Old 01-05-2009, 10:38 PM
juicersr's Avatar
Scott, pm sent
DZ12,935K3,934,2.8RSR
Ducati 900ss/GhezziBrian STW
dzugautomobili.com
Old 01-06-2009, 02:15 AM
12mm
It is common practice and sometimes even 10mm, there are great selections of race plugs ie. motorcycle plugs, and the main reason is the chamber vol. in the head is not increased like with the larger plugs.
Mike Bruns JBRacing.com
The two most useless things to a driver are the braking distance behind you and nine-tenths of a second ago.
Old 01-06-2009, 08:17 AM
Exactly the same opinion as Mike
Old 01-06-2009, 08:31 AM
abit off center
cgarr's Avatar
I only do twinplugged heads with the 12mm second plug because you leave more material in the head and with the 12mm plug you do not have any clearance problems with the stock head stud nuts.
______________________
Craig
G2Performance
Old 01-06-2009, 09:11 AM
930gt-40r's Avatar
Is it also good for combating cracking between the second plug and the exhaust valve seat area? This is what I have always thought to be the reason.
Kris @ Tech9
86' 930/GT-40R Sold
94' Rustang GT daily (long gone)
2008 C6/Z51 Corvette
Old 01-06-2009, 06:10 PM
