Chain fence eating turbo
Question 930.103.121.2 R - which conn rods is these?
First off, my car is an '87 Carrera 3.2 with a single turbo. After doing the "money shift" and tearing down the motor, I have been trying figure out which rods I have.
I cant find the origin of these rods in my 3.2. I tried Waynes Porsche PET links with no avail. I figured they were 930 rods because I have the flat top pistons for the turbo.
Also, is my barrels the stock ones with the part number: 95NZ1.......W16.........A8?
TIA, Cory
Cory - turbo'd '87 C3.2 Guards/Blk, 3.4, 7.5:1 CR, 993SS cams, Borg-Warner S366 turbo @ 1.2-1.5 bar, Treadstone full bay IC, 70mm TB, TiAL F46 WG, HKS 1 1/2" BOV, twin 044 pumps, MicroSquirt AMP'd w/GM smart coilpack, Bilstein coilovers, Tramont replica Speedlines (285's rr, 225's frt), Big Reds frt, 993 rr., tower brace, MOMO wheel
Old 12-29-2008, 05:20 PM
The 3.2 and the 3.3 rods are the same, having a smaller wrist pin then prior rods of the SC. The cylinders can be either Carrera or SC. If there is no head gasket CE ring the cylinders are Carrera. If there is a head gasket relief then they are SC
Old 12-29-2008, 05:32 PM
So you are saying I could have either 930 or 3.2 rod? Wow, so both rods are the same in strength I assume?
There were thin copper looking barrel gaskets at the bottom.
Old 12-29-2008, 05:43 PM
That is the base seal for the cylinder. The new ones in the kits are black
Old 12-29-2008, 05:57 PM
Jeff Alton's Avatar
3.2 and 930 rod is the same part, as is the 964 rod.......
Cheers
www.turn3autosport.com
Old 12-29-2008, 06:07 PM
So when you spoke of relief's, you were speaking at the top of the barrel?
Cheers
In the PET, all 911 engines from the first 'til 1989 showed a 930.103.XXX.X designation.
Then, the 964 rods said 964.103.XXX.X followed by the 993.103.XXX.X for the 993's of course.
So mine, has the same 930.103. as all the others but none in the PET had the 121.2 R suffix as my rods have.
So, I still have just a regular 3.2/3.3 rod?
Old 12-29-2008, 07:23 PM
up-fixing der car(ma)
YTNUKLR's Avatar
Send a message via AIM to YTNUKLR
yes, 3,2/3,3 rod
Scott Kinder
kindersport @ gmail.com
Old 12-30-2008, 02:06 AM
Jeff Alton's Avatar
Open up many 3.6 964 motors and in them you will find rods with 930.103.....
Cheers
Old 12-30-2008, 06:10 AM
Originally Posted by YTNUKLR View Post
yes, 3,2/3,3 rod
Ok, thanks Scott
Cheers
Humh.....interesting information...... thanks Jeff
Old 12-30-2008, 06:36 AM
