-   -   What cuts Yamabond (spl) (http://forums.pelicanparts.com/911-engine-rebuilding-forum/450017-what-cuts-yamabond-spl.html)
OldTee 01-06-2009 01:52 PM
Or will disolve it?
barney911rs 01-06-2009 02:25 PM
I assume you mean to clean case halves. I've just done it by hand with a scraper and razor blades. Other then that, can't help you.
Henry Schmidt 01-06-2009 03:34 PM
Scotch Brite, MEK and a respirator. Gloves are also a good idea.
If you have a stainless tooth brush, they work good too.
*If you use MEK please remember that it is very toxic. Don't use it in a confined space and limit your physical contact.*
David 01-06-2009 06:28 PM
Berryman's carb cleaner works for me.
OldTee 01-10-2009 03:25 PM
How I did it. First I bought a $1.58 aluminum baking pan from the $ store. I added about a 1/4 inch of varsol (paint thinner) from Home Cheapo. Put the cam tower flat into the pan and set it out. A day later I came back and used a brush I bought from Harbor Frite Tools for about a buck and a pot scrubber I stole from the Mrs and scrubed away. That took away about 90% of the mess. Then I used the same pan and put in 1/4 inch of lacquer thinner and set over night. That did it. The pot scrubber and brush cleaned it.
Mrs wanted the pan but it has already gone to recyling.
