OldTee's Avatar
What cuts Yamabond (spl)
Or will disolve it?
Old Tee
all 911s sold
Old 01-06-2009, 01:52 PM
barney911rs's Avatar
I assume you mean to clean case halves. I've just done it by hand with a scraper and razor blades. Other then that, can't help you.
John Snodgrass
1973 Porsche 911 "Barney" (race car for sale)
2008 Nissan Maxima - Daily Driver
1999 F350 Diesel Crew Cab - Tow Beast
1990 Airstream 36' Land Yacht - Home Away From Home
Old 01-06-2009, 02:25 PM
Try not, Do or Do not
Henry Schmidt's Avatar
Scotch Brite, MEK and a respirator. Gloves are also a good idea.
If you have a stainless tooth brush, they work good too.
*If you use MEK please remember that it is very toxic. Don't use it in a confined space and limit your physical contact.*
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 01-06-2009, 03:34 PM
David's Avatar
Berryman's carb cleaner works for me.
Old 01-06-2009, 06:28 PM
OldTee's Avatar
How I did it. First I bought a $1.58 aluminum baking pan from the $ store. I added about a 1/4 inch of varsol (paint thinner) from Home Cheapo. Put the cam tower flat into the pan and set it out. A day later I came back and used a brush I bought from Harbor Frite Tools for about a buck and a pot scrubber I stole from the Mrs and scrubed away. That took away about 90% of the mess. Then I used the same pan and put in 1/4 inch of lacquer thinner and set over night. That did it. The pot scrubber and brush cleaned it.
Mrs wanted the pan but it has already gone to recyling.
Old Tee
all 911s sold
Old 01-10-2009, 03:25 PM
